Old 12-16-2008, 06:45 PM   #1
art leong
Default What do LS1 guys do for a 2 step?
What do LS1 guys do for a 2 step? I'm using an LS1 coil over plug setup. I'm not using a distributor.
Art Leong 2095 SS
Old 12-16-2008, 10:06 PM   #2
Chad Rhodes
Default Re: What do LS1 guys do for a 2 step?
MSD DIS-4, x2 in the case of an LS1 or later mod motor mustang
Chad Rhodes 2113 I/SA
Old 12-17-2008, 11:11 AM   #3
art leong
Thanks. I was hoping there was something else made for the application. I've had nothing but greif from the msd dis2 so far.
Art Leong 2095 SS
Old 12-17-2008, 03:48 PM   #4
casper
casper's Avatar
not sure what kind of ECU you are running , but the F.A.S.T. unit has a built in 2-step .
It's not quite as "tight" as I am used to ( MSD on a non EFI application) but it seems to do the job .
Mike
casper is offline   Reply With Quote
Old 12-17-2008, 06:14 PM   #5
art leong
I'm running a ViPec ecu. It has a 2 step type feature but it isn't what I want. They are going to work on the firmware to fix it, but I realize they have a lot of other projects in the wings. So I'm ready for plan B.
My least favorite race car electronics are FAST and MSD.
I had nothing but trouble with the msd dis 2, had 1 of them go bad, called msd about it. They swore it couldn't be the unit, it must be my install, or something else. After wasting hours on the dyno, with an intermitant problem. I sent the unit back and guess what!! It was bad!!!!
The fast system wasn't much better idling at 1500, not wanting to start, changing the timing at will, etc. With absolutly no help from fast.
I fire sold both units. Put in the ViPec. The car idles at 800 drives around the pits like a golf cart.
If I have to go back to the MSD I will but I pray there is another way to a 2 step.
Art Leong 2095 SS
Old 12-17-2008, 06:24 PM   #6
TOSTO RACING
TOSTO RACING's Avatar
Liked 663 Times in 187 Posts
If you run the stock coil packs Lingenfelter makes one which is what I'm running.
http://www.lingenfelter.com/store/l460095297.html
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is online now   Reply With Quote
Old 12-17-2008, 06:56 PM   #7
art leong
Thanks. I'll contact them and see if it will work with my 4 cylinder.
Art Leong 2095 SS
Old 12-17-2008, 09:49 PM   #8
JeffM
Liked 5 Times in 5 Posts
sorry, didn't see the post above.
JeffM is offline   Reply With Quote
