Old 12-10-2008, 01:46 PM   #11
CH.CRAFT
Location: PORT ALLEN, LA. NEXT DOOR TO STATE CAPITOL RACEWAY
Default Re: fuel cell choice
I have a 12 gal.harwood plastic with the original foam in my 68 camaro i bought/installed in 1985, no issues, it must be some good foam i guess.
CH.CRAFT is offline   Reply With Quote
Old 12-23-2008, 07:39 PM   #12
ron b
Liked 4 Times in 4 Posts
Default Re: one more question
Originally Posted by greg fulk View Post
Once alum is bolted down it's grounded. Also a plastic cell over the years of setting in a hot trunk will start to loose it's shape as the heat & pressure from the hold-down straps wear on it. Oh & alum looks PRETTY!
are you using the tabs to mount it or are you using straps also. thanks
ron b is offline   Reply With Quote
