Old 11-19-2008, 06:00 AM   #21
Bud Lefevre
Bud Lefevre's Avatar
Default Re: 8.5" GM Ten Bolt
Originally Posted by Tod Lane View Post
Can this rear end be built to survive 450 HP in a 3300 lb automatic car, or should I just junk it and spend the extra for a 12 bolt?
Any other advantages to a 12 bolt besides strength?
You never mentioned what kind of car ?
Bud Lefevre 3075 STK
IHRA World Record Holder
Bud Lefevre is offline   Reply With Quote
Old 11-19-2008, 06:13 AM   #22
Robert Swartz
Robert Swartz's Avatar
"This would be a second gen F body crate motor car" quote from a previous thread by Tod Lane
Jigs up. Bud, it's the same car I brought up in "Starting a new stocker thread". 1979 Firebird T/A for a possible crate motor stocker combination. Tod and I are partners in this venture and a bracket car.
"mew", hmm, teach me to write at 5:00am, good thing I majored in English.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 11-19-2008, 08:27 AM   #23
bobby
bobby's Avatar
Originally Posted by CrateCamaro View Post
U sure thats the same diff as the GM 8.5? The only rear that I know of that had pressed on bearings was a BOP 8.2. I know theres a difference for sure and parts availability is nill.
YES, it is. the only difference is that they have press on axle bearings. I have put 77 Camaro guts inside of one, if that says anything.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 05-30-2009, 09:22 AM   #24
Nitroman
Nitroman's Avatar
Does this particular diff have provisions for a torque arm ?? And do you still have it ?
Nitroman is offline   Reply With Quote
Old 06-01-2009, 11:17 AM   #25
2Ton71
2Ton71's Avatar
Liked 9 Times in 3 Posts
I'm running a 8.5 10 Bolt in my 1971 Caprice. It weighs 3950lbs, and I've been 1.45 60ft. 10.74@125 with a small block. Footbraking.
I run it with a Moser spool, 33 spline axles, LPW girdle, and C-clip eliminators.
They'll hold up if you set them up right. I've ran it with that combo since 2005.
2Ton71 is offline   Reply With Quote
Old 06-01-2009, 01:13 PM   #26
s10stocker
s10stocker's Avatar
When I purchased my 1996 S10 brand new in March of the same year I had no idea that I had a 8.5 10 bolt in it. Now being a stocker I consider that my lottery being that every other S10 I new up to that point was a 7.5. All I did was C-clip elims, spool and Richmond 5.38/5.57 gears with stock axles with high 1.5s and low 1.6s short times at 2950 lbs up to 3300. Now if your looking for a S10 8.5 here is what you must look for. They only came with the 96-03 L35 4.3(W on 8th digit of vin) mated to a 5 speed. They did come in more than one width however being the S10 ZR2's RE was about 7 inches wider. It sure does feel nice to give some input on something on here that I don't feel like everyone knows already.
George Roussel Jr. 4262 1996 S10 n-o-p/sa
s10stocker is offline   Reply With Quote
Old 06-01-2009, 04:17 PM   #27
George, What is the width of the narrow (drum brake) version (drum to drum, outside)?
Thanks
Old 06-01-2009, 09:09 PM   #28
s10stocker
s10stocker's Avatar
Thanks
55 inches for the regular S10 65 inches for the ZR2. Just crawled under each to make sure. The ZR2 footprint isn't 10 inches wider however due to the amount of backspacing like a FWD car.
P.S. The ZR2 also has disk brakes.
Old 06-01-2009, 11:08 PM   #29
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
I wish I could get a hold of a 8.5 10 bolt for a fourth-gen f-body. Would beat the hell out of having to carry the extra weight of a 12 bolt, and still have more gear selection than the 7.5 10 bolt.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 06-03-2009, 01:03 PM   #30
s10stocker
s10stocker's Avatar
What is the width of your rearend bolt face to bolt face?
