Old 12-09-2009, 08:40 AM   #1
Ross Family Racing
Liked 51 Times in 14 Posts
Default Need Intake for 426 Street Wedge
Looking for an OE intake and carb for '64 Plymouth Fury with a 426 Street Wedge motor for Stock Eliminator. Anyone out there have one?
Jeff Ross
Ross Family Racing is offline   Reply With Quote
Old 12-09-2009, 02:29 PM   #2
treessavoy
Liked 4 Times in 4 Posts
Default Re: Need Intake for 426 Street Wedge
Jeff,
Are you looking for the 514 head?
You can find the same head in 413's and 383's of the same era.
I'm looking to build the same combination next year and bought a complete 413 and '65 trans with the 514's. I would be glad to exchange ideas or help as best I can.
I live in FL and will visit Dvorak and see if he has any heads or you can contact him yourself at 352-468-1353.
Good Luck.
JimR
Jim Rountree
Old 12-09-2009, 03:56 PM   #3
FED 387
Liked 333 Times in 180 Posts
Question Re: Need Intake for 426 Street Wedge
have a neighbor that is a packrat---has a 3611 Carter carb needs to be rebuilt ---missing a few choke pieces but other than being dirty everything moves freely---interested?? Comp387
Old 12-09-2009, 10:01 PM   #4
jdfpam
Jeff,
I talked to Al about this a few days ago. What casting number intake do you need? Also, I believe the heads that you need are 516, not 514. If so, I have a few pairs of castings that I would be willing to sell.
Talk to you later,
Jeff Day
jdfpam is offline   Reply With Quote
Old 12-10-2009, 01:31 PM   #5
treessavoy
Originally Posted by jdfpam View Post
Jeff,
Talk to you later,
Jeff Day
Jeff,
You're right on the heads, 516's. my fingers aren't that smart. Also I was told by the NHRA that any Mopar head could be used that had the same valve size and chamber spec's as the 516's could be used ie the 915 with same valve size.
Would the intake and carb be the same as the 413's of '64 and '65? It's not that hard to still find the 413's in junk yards.
JimR
Jim Rountree
Old 12-10-2009, 11:24 PM   #6
James L Miller
Liked 25 Times in 16 Posts
NHRA lists the 915 and 516 heads as legal for the street wedge in stock.
D = 2406516,2780915, 4532287 SS only
They don't list any intake casting numbers, but for the 383 they show some of the later 69-70 383 intakes as legal. Maybe you can use a 440 AVS intake and be legal? Didn't the early AFBs use a smaller bolt pattern? How would the early carb bolt up to a later intake? Maybe they allow for replacement AFBs like a 9626S or something? Sounds like an e-mail to your tech director may be in order.
Mopar 2 Ya!
Old 12-13-2009, 01:48 AM   #7
GTX JOHN
Liked 2,486 Times in 697 Posts
I understand you can run the 915 heads if you use the 1.60 exhaust valve. These are way better than 516. To ID them in junkyard look on front machined area behind Alternator and if stamped HP they are 1.75 ..... if not stamped 1.60. If you can run 67-69 Intake for 440 (178) which I don't know.. It is also way better. I have several of each. Racer7411@yahoo.com
Old 12-13-2009, 01:31 PM   #8
340Cuda
Liked 801 Times in 338 Posts
I have a friend that has some tall block single four barrel manifolds and some carbs.
Can you give me the casting numbers and carb numbers that will work for you?
Thanks,
Bill Lamb
Old 12-13-2009, 05:28 PM   #9
John Lang
Liked 6 Times in 2 Posts
Thumbs up Re: Need Intake for 426 Street Wedge
FED 387 ! I could use the 3611 carter, even if their are parts missing ! I have lots of parts ! Let me know what he wants for it !
Yes , I still live in Sheboygan ! .......Merry Christmas.......John Lang
I tried to send you a private message ,but could'nt because your box was full !!!
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
Old 12-13-2009, 08:12 PM   #10
Mopar Steve
The 426W Single 4 intake pn is 2206000.
Mopar Steve is offline   Reply With Quote
