#141 |
Instead of complaining about the new car's with the bogus hp ratings, maybe the old iron should get factored down a class or two?
Jerry Williams NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's. |
#142 | |
So, 20 or so combinations (or more) should be adjusted instead of the 1/2 dozen or so new cars being correctly factored, or put in their own classes? And when you "factor the old iron down a class or two", what happens to the cars already in those classes?
Alan Roehrich 212A G/S |
#143 | |
NHRA has already accepted these new cars in Stock. It is what it is. Maybe create a new AAA/S class and save the old records and classes?
#144 |
Liked 58 Times in 18 Posts
It's fix the current problem not make more problems, the least they should do is reinstate the F.I. classes. but these cars should be in super stock, they are not for sale to the public the are parts counter cars- no vin, no reg, no lic plate, not stock production veh. and lets not forget waaaaay under rated!!!!!
#145 | |
#146 | |
#147 |
Liked 52 Times in 17 Posts
Greg, help me out here. I don't have the time to fuddle around the engine guide, how many of these "new combo's" are injected or carb'd ?????????? Can they go both ways? Thx. B
Bernie Cunningham 7053 STK |
#148 |
Liked 279 Times in 68 Posts
Bernie, they are all fuel injected. Just to give you an idea the 352 Ford I started talking about on this thread compared to your LT! has more compression, better heads, larger solid roller cam, 1000 cfm throttle body, better intake and is rated at 285hp compared to your LT! at 346hp. I truly think most people are not aware of how these crate motor combos are going to affect them yet. Take a look at the 2010 Ford specs and the 2009 Chrysler specs.
Greg Hill 4171 STK |
#149 |
Correct me if I am wrong but didn't the LT1 start out at 275hp?
Chuck Beach 3340 STK |
#150 |
Made a mistake.
