#11 |
Liked 175 Times in 78 Posts
Won't make any difference if it is 50 lbs over C/SA weight as Toby reported.
It will still make B/SA and will not have to change the weight :-) peace
time is our most precious resource, you can always make more money but you can never make more time spend your time wisely with the ones you love - Ron Durham |
#12 |
Liked 2 Times in 2 Posts
Grossi went 1.251 under at Vegas Jan a year ago and got 9 HP.
#13 |
Liked 10 Times in 6 Posts
Mark Yacavone, it still shows McClanahan 2002 Pontiac Firebird got hp. on 7/10/10. Tom
Tom Moock 5704 STK |
#14 |
Liked 2 Times in 1 Post
#15 | |
Well, if it's true they can't get it any lighter, it will be a C only car next year because you can't weigh more than the minimum for the next heavier class. Once they get some more HP it won't be a problem though. -Toby |
#16 |
That is what I am saying Toby
Give it 20 HP and it is a "B" car and it is already the correct weight If it does not get HP- it moves down to "C" and will be an even faster "C" car to the index Complicated sometimes to figure out what should be done Of course I am hoping for a couple of FX classes with one for V10s only - LOL :-) peace
#17 |
Liked 20 Times in 3 Posts
The 12 HP that the LS1 received was returned, its back to 342 for the ram air/ss hood combo. However, it was not because it was at a factored track. It clearly states in the new rules that factored tracks are included in the instant hit when going 1.25 or more under. The LS1 was singled out when it was given the 12 HP (there were several other cars that went more than 1.25 under and did not get HP) This was pointed out and presented to the committee.
#18 | |
Seeing it's still the same year, I wouldn't expect to see it happen. Next year , with a revised or rewritten rule and a prominent warning, it probably WILL happen. Then again, who knows?
#19 |
Liked 125 Times in 40 Posts
Did Roy Hill receive h.p. last Tues.?
Sean Cour T6066 ladle |
#20 |
Liked 3,207 Times in 979 Posts
For those who don't know...(not you Sean)
Yes, his combo is now 534 as of 11/2.
