#81 | |
i doubt you can out wheelstand some of the 427/396 camaros. Hell i know of one orange 69 camaro that i KNOW you can't out wheelstand.
Chad Rhodes 2113 I/SA |
#82 |
What is your index with the 330 hp crate engine, and what do you have to weigh?
And I'm not trying to argue. Just curious. I don't run Stock, so don't really care either way about this.
Ed Wright 4156 SS/JA |
#83 |
Liked 100 Times in 45 Posts
Don't like the rule structure?Stay the f*ck up in Canada and have fun with your bracket car.We try to give a civil conversation and you both admit you just wanted to stir the $****.
a$$holes like you two give some a bad view if Canada.Mybe you should spend time rolling the stone in the exciting game of curling. Those jr dragster kids are waiting to kick Mr F Bombs ***** if he has the balls to venture into the real world.
Former NHRA #1945 Former IHRA #1945 T/SA |
#84 |
Ed, you really need to come out of your shell, and say what you really think. LMAO!
#85 | |
Liked 19 Times in 7 Posts
just got de-rated from 340 back to 330 When it was 340hp I had to weight 3400lbs I actually crossed the scales at 3465 with me in it. So its not that easy to make it happen. This year will be worse because of the -10 decrease in hp. Might have to move into I/CM because I dont have the heart to gutt the car to find 96 lbs.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
#86 | ||
Liked 13 Times in 9 Posts
![]() Actually, I'm still trying to figure out what the argument *is* here... 1) NHRA's not going to change anything so it's a moot point for one side to push the argument, and at least as bad for the other side to get defensive about it, and 2) you've got a guy that built a car to the rules that he wanted to build, and has fun with it. All this NHRA vs IHRA or this car vs that car stuff is irrelevant. Quote:
360 crate - 9.6:1 comp, .458/.467 cam w/ 1.6 rocker, .060 dish piston, 1.925/1.625 head, 57.7 cc 340 standard - 9.32:1 comp, .462/.473 cam w/ 1.5 rocker, flat top piston w/ notches, 1.88/1.60 heads, 64.7 cc What's all that worth on the track? Ahdunno. The crate motor has some intake/carb advantages, etc which offsets some of the 110lb (260lb?) weight difference, but they're certainly more comparable than the new cars. The 360 DragPak has better specs all the way around than my crate motor, and it's rated 50hp less (which is why there's more than one being put together at Sloan Racing Engines) I have no problem with crate motor remaining solely an IHRA thing. *IF* NHRA ever did anything (and I don't think they would), you'd think they'd show up in Super Stock GT first. Come to think of it, you'd think it'd make sense to combine crate motors in IHRA with Stock GT. /ramble
#87 | |
#88 |
#89 |
Liked 19 Times in 2 Posts
Not for nothing, for all the arguing going on here, this could be Ed Fernandez's long lost brother.
Mike Ficacci Stk 1010 |
#90 | |
