Old 08-01-2011, 11:19 AM   #1
chevy 68
chevy 68's Avatar
Default Front Tire Size
I have a 26" front tire and I consistently cut .040 lights. What size tire would I need to cut .015 to .020 lights? 24" tires?
chevy 68 is offline   Reply With Quote
Old 08-01-2011, 01:16 PM   #2
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Default Re: Front Tire Size
More Air!
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 08-01-2011, 02:53 PM   #3
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
You might have to take a bump or two.......might want to try some more rear tire pressure too to speed up the cars reaction time a bit, of course a bit higher launch RPM, will not hurt along with higher front air pressure...
Eric
Eric Merryfield 1883 STK
Old 08-01-2011, 03:25 PM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Front Tire Size
I went from 26" to 28" to slow my RT down a bit, but it was several years ago. I'm pretty sure it was at least .10, but don't recall the exact #. You can still add air to fine-tune it for quicker RT's. But the size change will make more difference than front tire air pressure adjustments within safe/resonable limits.
Check front and rear suspension bushings for wear also. New ones will firm things up.
6-8 point roll bar and/or frame connectors already in? That should also help.
Old 08-02-2011, 12:10 PM   #5
cad
cad's Avatar
Liked 93 Times in 52 Posts
^^Agree. Leave it and add 6-8 pounds of air...or launch at a higher RPM.
Clark
Old 08-02-2011, 08:27 PM   #6
Tim Ellis
Liked 7 Times in 6 Posts
In my opinion 6-8 lbs of air won't even be .01 improvement
Tim Ellis is offline   Reply With Quote
Old 08-03-2011, 01:19 PM   #7
cad
cad's Avatar
I footbrake with no 2 step (currently). It doesnt mention what launch control setup... 6-8 pounds and changing RPM will affect mine enough...
Old 08-04-2011, 11:00 AM   #8
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
2" diameter change in front tires can be .010-.015.
This depends on what the change in air pressure is, "from what, to what". 40 to 46psi? No, you're not going to see anything. 30 to 36? Yes, definite change.
I wrote an extensive (10+pg) editorial on www.thisisbracketracing.com covering bottom bulb reaction times and how to adjust them. It is a subscription site, but worth every penny and then some.
Old 08-05-2011, 03:08 AM   #9
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
I have seen Dad as low as 18lbs on the 26"! I bought him a set of 28" old school Moroso he runs some where around 30 now.
