Old 11-16-2011, 10:01 AM   #1
Johnny McDermott
Default Hoosier tire compound recommendation for bias 9X30
Hello,
A poster on YB recommended that I post this question on this forum.
For a 3800 lbs., 3 speed automatic, footbraked 10 second car would you recommend the 9X30 bias ply tire in the D05 or D07 compound?
One response on YB hinted that D07 is a manual transmission compound. Does this indicate that it is firmer than the C07? Is the car too heavy for the D05?
Thanks.
Johnny McDermott is offline   Reply With Quote
Old 11-16-2011, 01:01 PM   #2
69Cobra
Liked 2 Times in 2 Posts
Default Re: Hoosier tire compound recommendation for bias 9X30
I believe he is correct. My car is about 3800# and when I used to run Hoosiers I ran the D07 but I run M/T's now and I don't think I'd go back.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 11-16-2011, 01:15 PM   #3
Greg Hill
Liked 279 Times in 68 Posts
Use the Hoosier radials in probably the CO7 compound. I run the CO6's and have been in the low 1.30's in 60'. I think the radials are more consistent than the bias. The CO7's have a stiffer sidewall and a little more rubber on the tread but the 6's are lighter.
Greg Hill 4171 STK
Old 11-16-2011, 01:55 PM   #4
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
My car is 3600 lbs I run the radials in C06 they work great!
Old 11-16-2011, 02:37 PM   #5
Run to Rund
Liked 54 Times in 27 Posts
D07 is for manual trans. Hoosier tech can probably make a recommendaton for you.
Hoosier Racing Tire Corp.
65465 U.S. 31
Lakeville, IN 46536
Phone 1-574-784-3152
Fax 1-574-784-2385
Old 11-17-2011, 09:49 AM   #6
Johnny McDermott
I've got a radial but I'm looking for a super hooking bias to be more consistent with. Since only the two compounds are offered in the 30X9 inch size should I look at a slick from another brand for my application?
Goodyear, M/T?
Old 11-17-2011, 05:45 PM   #7
brent flynn
brent flynn's Avatar
Goodyear, M/T?
9x30 Pheonix Bias ply... 150 passes and were still hookin on low 11sec bird at 3600lbs 1.48-1.50 60fts... not a stocker, but a cheap 455 bracket motor with 4.11 gears... great tires. I pulled them off when check holes were disappearing... they had alot more runs on them... it's a footbrake car too.
Old 11-23-2011, 10:48 AM   #8
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
18200 D05 compound
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
