Old 11-17-2011, 07:48 AM   #11
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: Reusable oil filter
Ed; Do you play the Loto, also?
Old 11-17-2011, 09:33 AM   #12
Bill Baer
I use the System One filter. It is simple to remove and clean. real nice to check on the internals in the engine. no more cutting stock type filters. I lost 2 engines due to elcheapo AC filters. The internals in the filter colapsed and cut off the oil. No more regular filters for me. I highly recommend the System One filter.
Ah yep!
Old 11-17-2011, 11:39 AM   #13
tj310
I prefer the Moroso screen. I have a System one sitting on the shelf collecting dust. If your collapsing filters your running too much pressure, too thick an oil, and disabled the filter bypass. I also prefer the Fram filters with the gripping surface we remove them after each day to look at the screen. With our headers you can remove the filter , move it sideways, and use a mirror [or a second set of eyes ] to look at the screen without twisting the filter out and spilling the oil all over the headers. I reuse filters about 6 times. ----Thanx Trevor
Old 11-18-2011, 11:44 PM   #14
Sam Murray
Sam Murray's Avatar
Liked 60 Times in 29 Posts
System one is the only way to go. I've been using them for 14 years and never an issue easy to clean and monitor. I usually go 20 to 25 runs an oil change. Expensive up front but it more than pays for it self in the long run. Probably could use the Moroso screen with it also if you look at the filter daily!
Sam Murray
1616 STK
Sam Murray is offline   Reply With Quote
