Old 11-25-2011, 11:44 PM   #1
ron b
Liked 4 Times in 4 Posts
Default 5 point harness roll bar weld tabs
i am currently using a 5 point harness wrapped around the seat bar, tech wants me to use weld tabs. i could use a couple suggestions and pictures of what angle you welded them to the bar, 1968 mustang coupe. thanks ron b
ron b is online now   Reply With Quote
Old 11-25-2011, 11:52 PM   #2
cad
cad's Avatar
Liked 91 Times in 51 Posts
Default Re: 5 point harness roll bar weld tabs
I just have one and is on the rear side of the cross bar pointing down. Ensure you have enough room to get the bolt and nut through the hole before you finish weld the tab.
Old 11-26-2011, 11:30 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Wrap around attachment is perfectly legal as long as the harness has something to limit sideways movement , of course you dont want to bunch them up on top of each other to go over the seat.
If you use a bolt in V harness the anchor point is supposed to be no more than 4" below the top of the drivers shoulder.
this is a problem on many older roll bars ,as the shoulder bar is placed too low in relation to the seat, but has sort of been overlooked by tech guys in the past.
There seems to be a new interest in harness mounting by tech inspectors ,as I've talked to several racers who have been told to relocate their harnesses when having the chassis cert renewed.
I use a large chassis tab welded to the bar at an angle that allows the harness to follow a natural line over the shoulder.
