I just went through a number of old threads on 2-steps.
I think my head is going to explode ! Brake pressure switch ??????? WTF is that for ????? Anyhow... I need to get my 2-step wired into my car ( along with the line-lock that I still haven't installed ). I need it to hold about 6000 RPM while in first gear, clutch pedal depressed... But once I leave... allow me to shift around 7000. How the heck do I do that ? ! I'm expecting a big education here !
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 |
Put a switch on the shifter that over rides the two step. Probably will be where you have your line lock switch now.
2009 V/SA Record Holder |
Liked 783 Times in 195 Posts
Brake pressure switch on a stick shift car helps you be consistent. When you stage the car, find through experimentation what is the minimum safe brake line pressure necessary to hold the car still while staged. Then the release time of the brake system becomes a consistent factor in the "leaving event". The more pressure you build into the brake system, the longer it takes to release it.
Since you currently do not have a line lock, the brake pressure switch is not an issue, unless you have three feet. |
Liked 11 Times in 8 Posts
This is easy, you need a switch that activates only when the clutch is pressed completely to the floor, I use the arm type switches the chassis places sell cause they're easy to adjust. You can use this set up cause no one presses the clutch completely to the floor on a gear change, believe me I know it works. I've wired up a relay in the past hooked to the line lock that deactivates the line lock on clutch release that way you have the line lock holding the car in the beams. Joe
Joe Buchanan SS/BX 3117 |
Liked 1,923 Times in 432 Posts
http://www.msdignition.com/uploadedF...structions.pdf
See figure six. That allows you to hook up a line lock and a clutch pedal switch on a stick car. Once you stage, and step on the clutch, release the line lock button, the switch on the clutch pedal holds the line lock, holding the car on the starting line until you let the clutch go.
Alan Roehrich 212A G/S |
Wow, thanks Alan I've never seen this before basically how I had my stick car set up. Their schematic is much easier to read than my "art work" thanks for the link guess I never thought to look there.This looks very easy to set up. Joe
#7 | |
It's easy enough that even I could do it! It takes a lot of opportunity for "stupid" away from the driver, not enough to make up for my having not raced a stick car in near 20 years, but it helped. We had it set up on an MSD 7AL-3, it worked like a champ, especially when the 220# of ballast that was holding the steering wheel did its job. Which was not often enough. I think I made a dozen passes in that car in a year, only 4-5 of them were decent.
#8 | |
I tend to seize every possible "opportunity". Thanks people ! Now, with a couple switches and about 8 wires to install... the question becomes... will I have enough time between now and May, to figure out how to do it ?
#9 | |
Liked 503 Times in 131 Posts
thanks Eric
Eric Merryfield 1883 STK |
