Old 02-18-2012, 04:14 PM   #1
Speedy Peets #4103 I/SA
Liked 5 Times in 4 Posts
Default rear ends chevy
went to put my rebuilt rear end back under the future stocker, lost my u-bolts and a guy who does leafs sold me new ones, gave me 4 u-bolts, do i need to throw the little bolts that were on the bottom side to hold the bracket for shocks away? thanks y`all,
Speedy Peets #4103 I/SA is offline   Reply With Quote
Old 02-18-2012, 06:33 PM   #2
eddie c
Default Re: rear ends chevy
Before I could honestly answer your question,I would need to know what
type car and year you are talking about. Also some better explaination
on what parts you are asking if "ok" to throw away. It may be best to send a few pictures of your differential and shock set up also. ed
eddie c is offline   Reply With Quote
Old 02-18-2012, 07:00 PM   #3
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
x2
Bob Bender 144 O/SA
Old 02-19-2012, 09:37 PM   #4
on the rearend on the inside where the axle tubes lay on the springs, where the shock mount comes up underneath the axle, there were twobolts about 1 1/2 long factory bolts that helped secure the plate where the rear shocks mount and your u-bolts mount on other side of springs, hoppe this helpsi`ll try to get my computer guru to add pics if needed, thanks y`all
Old 02-19-2012, 09:51 PM   #5
Doug Blackley
Doug Blackley's Avatar
Sounds like you are describing the T type bolts some used in place of the u-bolts. You can use either. What are going with for traction aid? I would lean towards what that system uses for hardware.
Doug Blackley 1697 STK
Old 02-20-2012, 10:11 AM   #6
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Get rid of the T bolts and use the U-bolts.
Joe Marcinowski 3377 STK
Joe Marcinowski is offline   Reply With Quote
Old 02-22-2012, 11:44 PM   #7
gonna go with the Competition Slide-a-Link, and Thanks you Guys for y`alls help, Good Luck to Y`all This Year
