Old 05-02-2012, 10:30 PM   #31
Hemi Moose
Liked 12 Times in 12 Posts
Default Re: wrong spec submitted by MOPAR
I was just thinking, does anyone know which Drag Pak Challenger it was...the Hemi or V-10 that got tagged?
Old 05-02-2012, 10:53 PM   #32
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
Yes it was the V10
BTW - all of the V10s were/are really nice cars from MOPAR
I hope it turns out to be as good of an investment as it has been fun
Ron
Old 05-04-2012, 03:22 AM   #33
SS Engine Guy
Trusting the supplier to do the right thing is the wrong thing to do. The builder should always verify what can and can't be done with tech. Usually in the form of a letter. (however, in the past few years, even a letter isn't worth the paper its written on). There lies the problem. Tech has been over ruled so many times that its all BS. I have freshened many "legal" pieces that had the proper # as per tech and were built totally different than the spec or intention of the rule. Its not hard to stamp letters/numbers/logos on parts.
Like Alan, I have had parts held for long periods of time, finally approved and then notified weeks and even months later that the approval was void. I have made it right by re-doing parts, no charge, even to the point of buying the newly re-defined part at my own expence along with machine work and other parts that were necessary to make this piece "legal" and make it work correctly. Then watch what I was NOT allowed to do go right thru teardown without a word said.
As much engineering and design as was supposed to be done on these super car engines (Ford,Mopar and probably Chev.) there is no excuse for any of these people to be dq'ed. Except for the fact that there is apparantly a lack of knowledge as to the amount of blueprint time required to build a truely fast and completely legal S/SS combination under the rules and guidelines set forth by the santioning bodies. Also, a lack of communication between manufacturers and tech. The attitude of building a regular car seems to be: put it out there and we will work on the problems as they arise. Any dealer tech can tell you stories about the amount of tech bullitins, recalls, replace it free only if the customer complains enough, etc...
Sorry for the long post but I know what its like trying to get a straight answer from aftermarket suppliers and from tech depts. Also, I didn't know there were different ways of measuring the diameter of a valve.
SS Engine Guy is offline   Reply With Quote
Old 05-04-2012, 09:51 AM   #34
dwydendorf
dwydendorf's Avatar
Liked 19 Times in 7 Posts
Smile Re: wrong spec submitted by MOPAR
I was involved with the teardown of the Fords last year and in their case, part of the problem involves the way the specs are sent to NHRA in the 21st century. Now all the automakers have converted to metric (remember that?) and all the specs have to be converted to Inches. Stop and think about how much effort has to go into sending in the tech specs now, as opposed to how it used to be. It is not hard to understand why the car manufacturers don't send in all the specs for every car they make. Sometimes conversions are miscalculated and the problems begin. Most of the racers with the new cars are not doing their own engine work, so it is easy to understand how problems can compound.. How about giving everyone involved a little slack. It is not as simple nowadays to just send NHRA the specs as it used to be. Maybe it is time for NHRA tech to get in the 21st century and use the new metric specs. How many would like to see this?
ss/gt 93 t-bird
dwydendorf is offline   Reply With Quote
Old 05-04-2012, 02:42 PM   #35
novassdude
Liked 136 Times in 49 Posts
They should be able to send in the specs what ever way they want. i know on my didgital calipers it is a simple press of the button to switch to metric.
novassdude is offline   Reply With Quote
Old 05-06-2012, 03:39 PM   #36
Liked 1,912 Times in 429 Posts
By all means. They got 50-100HP worth of "slack" when they got factored. Poor OEM's, by all means, we need to cut them more slack for getting parts approved and getting the correct spec in the class guide. They should apply the same standard to the blueprint guide as they did the factors in the class guide. Anything within 100HP or so is plenty close, so why bother with correct blueprint specs. And I'm all heartbroke over that work load those poor guys are suffering, some of them haven't put a street legal car in the class guide for 4 years. I mean, damn, it's pretty tough to get the correct specs in the class guide for 1/2 a dozen engines. Heaven forbid they have to convert metric to inches, too! Oh, the humanity.
I suggest you go try to sell a product or service to an OEM using the crappy loose standards they've been using to submit specs to the class guide. I hope you don't care anything about staying in business, keeping your house, or eating.
Yeah, cry me a river, those poor, poor, destitute and over worked OEM's.
Old 05-06-2012, 10:03 PM   #37
David Barton
Sponsor
Originally Posted by Andys dad View Post
I know Arrow built these as good as any engine builder out there - they just did not know MOPAR made a mistake - they used the valve which was identifed to go in the heads - stock size for a Gen IV viper engine - The TI sheet was submitted to NHRA after the engine building started - the valves used were appearently incorrectly measured by MOPAR engineering - used a blue print to figure out how to do it - LMFAO
Ron
It sounds like Arrow is not up to speed on how racing NHRA Stock Eliminator works. I don't doubt they know how to build engines, but they really should have reviewed the spec sheets provided on NHRA's web site. Actually, they should have been one of the first people to point out the mistake if there was one.
I can guarantee you that if I built the engine I would have checked the spec sheet instead of blaming Mopar. Sure, maybe they submitted the wrong info, but the fact is that the rules were in writing and that is what we go by in NHRA.
David Barton is offline   Reply With Quote
Old 05-06-2012, 10:23 PM   #38
David Barton
Sponsor
Originally Posted by Irv Johns View Post
In my case there were no piston specs for the 392 till March of this year. My engine was built with Diamond pistons as per NHRA specified with NHRA Logo and Diamond pistons engraved on top (early Drag Pak pistons had no engraving on top that was added after the first ones went thru teardown). There was no part number or ring spec in book til this March. My engine builder only had what was available for specs last June when my engine was built. He trusted Diamond to build pistons per NHRA as they were a approved vendor.
We built a 392 last year but chose not to run it because there was no approved piston. We were told that if we ran a standard bore size it would have passed as a factory piston. But since we bored it out there was no way it would pass because there was no approved piston listed.
Old 05-06-2012, 10:31 PM   #39
Andys dad
Andys dad's Avatar
OK - I will make one last comment - there was no spec sheet.........get it.......the specs were not published until after the engines were built..... I am not sure how that process worked....if I could delete this thread I would - I was only defending Dave - sorry - my humble apologies to all of you top flight engine builders who know so much more than anyone else
Ron
Old 05-06-2012, 10:51 PM   #40
Tom P
Liked 239 Times in 94 Posts
Don't the OEM's usually measure differently than the total OD of the valve? I have seen the 428 CJ being called 2.06" in old Ford internal documents instead of 2.09".
