#51 |
Liked 5 Times in 4 Posts
Frank B. if 2 points of compression is worth 122hp. sign me up lol !!!!
#52 |
Liked 51 Times in 25 Posts
#53 |
Anybody that can't make that one run about a day under needs to find another hobby.
Ed Wright 4156 SS/JA |
#54 |
Liked 10 Times in 6 Posts
FrankB, The truck motor gets to use a bigger cam .430-.430 cam. Tom
Tom Moock 5704 STK |
#55 |
Look at the 86 blueprint. 165hp is a 305.
Dan
Dan Wilson, STK3171, K/SA |
#56 |
That makes more sense, and is what I think is actually correct.
#57 |
Liked 14 Times in 10 Posts
Truck blueprints are below the car listings. Same heads with more cc's and different piston. Still the ultimate dime rocket (for now).
#58 |
Liked 576 Times in 137 Posts
There's a 305 AND a 350. For whatever reason, the blueprint specs for car and truck motors are separated.
If you look at the 1986 Chevrolet blueprint specs...you'll see the 305/165. If you look at the 1986 Chevrolet TRUCK blueprint specs you'll see the 350/165. Last edited by Nick Heath; 06-12-2012 at 11:17 AM. |
#59 |
If the guide shows an '86 1/2 ton pick up with a 350" but no 305", the guide is wrong. Somebody writing the guide transposed two numbers. I have worked on easily a couple hundred 1986 1/2 ton 305"s, they are as common as dirt. I have never seem a factory 1/2 ton 350". This is Oklahoma, all these cowboys around here have at least one pick up. I have had a couple of pick ups through my shop. LOL
#60 |
Liked 53 Times in 25 Posts
Could just be a paper truck or just build for Ca you never know.
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
