#21 |
Liked 11,032 Times in 2,267 Posts
Very impressive run using that flat manifold that the 402 came with.
#22 |
Liked 279 Times in 68 Posts
Larry, be good.
Greg Hill 4171 STK |
#23 |
Liked 19 Times in 2 Posts
Regardless of what happened, the 402 rated at 417 would have been pretty useless kinda like when Henson hit the Mopar a few years back. Better for everyone that it didn't get hit especially being that it raced the "new cars" and the LS1.
Mike Ficacci Stk 1010 |
#24 | |
![]() I have discussed this in detail in many previous posts... ![]() Just to give you something to think about since you are a Ford guy, take as an example the reason why the Ford Cleveland head picks up power when the exhaust port and valve is reduced in size... ![]() |
#25 |
Liked 325 Times in 50 Posts
New Cars? I must have missed something here. Help me Greg. And to stick to the subject, there will probably be consequences. There ususally is. What manifold Larry?
Jeff Teuton 4022 STK |
#26 | |
Liked 10 Times in 6 Posts
"Intake Manifold 3933163 with an open plenum (divider cut down) is acceptable as of June 6,2002" Of course we all know that is bogus but what can be said other than the tech department accepted a modified replacement intake. |
#27 |
Tilburg , what I stated is that the rule say 1.20 automatic Hp . I have hit the trigger and got HP . The last time I got HP my roll cage was not legal but I still got HP . I did not mean to go 8.44 with the wrong roll cage but it happened and I still got HP . The same rule should apply to everyone 1.20 under you get HP thats the only thing I commented on .
Buy a cobra jet and hit my combo dont bother me a bit everyone else does Curious was it your car or a customers car that paid you to do the motor ? Surely you're not telling your customer to do his own stuff instead of having you mess it up are you My engine builder also made a mistake at Indy in 08 and I got a year off for the mistake
Bo Kenney Last edited by boster; 10-16-2012 at 07:49 PM. |
#28 |
Liked 2,360 Times in 467 Posts
Bo So if I claim a 350 ci and during tear down they find that It's really a 400 ci the 350 should still get hp. Are you serious. You think that a roll bar is the same as something not right with a motor. Now I have run Brian's stuff for many years and have been threw many Indy tear downs. Nobody needs to defend him. He has always been first class and so has his work. As far as I'm concered there is no one any better doing stock and super stock engines. Barry Parker one very satisfied customer.
#29 | |
Liked 1,952 Times in 439 Posts
You're comparing apples and oranges. An engine with the wrong size valves is illegal, as in it will not pass tech. Making any passes made with that engine invalid, for any purposes. Oh, and for the record, if someone got your combination hit with a car that would not pass tech, I would be diametrically opposed to your combination getting HP, regardless of whether or not it deserves about 25, at least.
Alan Roehrich 212A G/S Last edited by Alan Roehrich; 10-16-2012 at 08:44 PM. |
#30 |
This is about a car going 1.20 under and on the qualifying sheet , then saying it had the wrong heads and no consequences for the party involved .
My buddy at the race went 1.201 under and got HP and was not torn down .He thinks the timing system could have been off by a thousands or two but he still got hp as did 3 other cars . The 402 should have got HP according to the rules . I have no axe to grind or no intent to disrespect Brian Tilburg or the driver of the Nova my issiue is with the rule and how it was interpertid at the event . So now for the record if you dont pass tech 1.20 runs dont count ? what happens if you dont get torn down they count ? so if you make a mistake and dont get caught then its ok ? and if you make a mistake and come clean at tear down you dont get punished for the mistake ? Thats not how it work for me at the races
Bo Kenney |
