#71 | |
Bub Whitaker |
#72 | |
Liked 460 Times in 91 Posts
x2
Bob Bender 144 O/SA 2010-2012 National Record Holder |
#73 |
Sponsor
Liked 1,045 Times in 70 Posts
Hey Grumpy, see all the problems created when you hold it wide open? I'm simply trying to reduce stress and conflict in the world, while at the same time promoting peace, love, and harmony. Coexist baby...
#74 |
Liked 154 Times in 37 Posts
Short and sweet -------------It was an oversight ! A one man shop with 30 different motor combinations going at the same time. The engine builder has a track record of dozens of cars going fast and passing tear down time and time again. His skills and reputation are beyond reproach. A year suspension for this is rediculous. ( nitrous, big valves, roller cam, bigger piston domes, heads 10cc's short, strokers , now that's cheatin ) -------- Anybody read the Junior Stocker book yet? Now that's an eye opener, you talk about stretching everything to the max. ------ Here's just a few of the things I was bounced for back then and never got a vacation because they weren't FLAGRANT! Just not being able to race was punishment enough. ----- Clutch fan instead of a straight fan----1 degree too much overlap measured with a piece of tape around the balancer then streched out and measured with a vernier , never mind it was .020 short on lift. ( Alan can probably remember that one)--- 2#s too much pressure on a 84# seat but 30# short on the open ------A carburetor that Farmer said " didn't look right" ----- a camshaft that checked way to the good but the paint stripe was the " wrong color " ------ Like my comments or not I've been doing this since 1959 and earned my 2 cents.
66W30POST |
#75 |
Liked 79 Times in 7 Posts
Fletcher sorry! You no that you dont accomplish anything not holding it in the full length of time. I feel bad enough for other things that surrond this matter, this only made it worse. Almost as bad as my 6yr old getting his first win in his kart after trying for a year and a half. And have him come in smiling from ear to ear and they bounce him because his wheel base was 3/8in off how do you tell a 6yr old looking over his glasses we won but we didnt? All because dad changed tire that week and the back spacing was different.DAM DAD!!
#76 |
Sponsor
It only gets worse sport. The whole length of time / accomplishment thing has many downsides...
#77 | |
This was in the 90's
Art Leong 2095 SS |
#78 |
Liked 10,813 Times in 2,247 Posts
Dan do you feel OK!
#79 |
Liked 20 Times in 12 Posts
Art I remember you telling me this. Was this at a Div 2 race? I remember checking you in Orlando one year, when you had the 4door. You had stock pistons in your engine that had multi dishes in it and ALLOT of deck on the block...Man that thing was stock! Crazy.
#80 | |
Division 1 race Dutch Classic. The specs called for .004 above the bore. My pistons were .030 (or so) down the bore. They told me if the specs called for above the bore it couldn't be below the bore. And I got tossed. When I pressed for some logic. I was told that I could be building an advantage in piston to valve, by the lower deck height. I took the rule book and showed them that I could run 2 head gaskets of any thickness. And they told me that was different. BTW the motor is a non interference motor. I could cut the timing belt and spin the motor with the starter and have no contact piston to valve. That day I lost all respect for curt lashure.
Art Leong 2095 SS |
