Liked 100 Times in 33 Posts
Updating some heads to the "new 2009" rules. 1. "any valve job" Does this mean oem valve seat angle no longer applies (go from oem 30 degrees to 45 degrees or oem 45 degrees to 58 degrees?) ? 2. "bowl hawging" will pass tech as long as it is centered off the valve guide? 3. back cutting valves is ok? 4. Has runner volume been changed to account for these modifications (additional 2-3 cc's )? 5. Can heat riser ports be filled? ( "heat riser passage may be blocked from intake manifold side of cylinder head. Blocking passage down in valve pocket prohibited.") Thanks, Ron.
Liked 308 Times in 103 Posts
As I understand that is correct,can unshroud to head gasket bore,changing 30 to 45 or ? I think is allowed but have'nt checked,to verify that so I would check on valve angle. To decrease runner CC mill intake/ex surface.
I leave filler 1/8-3/16'' ish down in heat riser passage on bowl side,so it's filled but does'nt protrude into bowl area,and fill all the way to intake surface. I have another 200 BOP if interested Ron. Mike Taylor 3601 |
Thanks, Mike. Phone went dead. Talk to you later.
#4 | |
Liked 43 Times in 9 Posts
CYLINDER HEADS Must be correct casting number for year and horsepower claimed, per NHRA Technical Bulletins or NHRA accepted. Porting, polishing, welding, epoxying and acid-porting prohibited. Combustion-chamber modifications prohibited. Cylinder heads are additionally restricted in that they must retain original-size valves at original angles +/- 1 degree and must be able to hold original cylinder-head volume per NHRA Specifications. Runner volumes may not exceed the current Super Stock cylinder-head volumes as listed on www.NHRARacer.com. Regardless of the poured volume measurement, any modifications to intake or exhaust runners prohibited. Any evidence of modifications from the original castings will be grounds for disqualifications as determined by NHRA in NHRA’s sole and absolute discretion. Any aftermarket steel valve permitted, must retain stock head and stem diameters. Only engines OEM-equipped with sodium-filled valves may use sodium- filled replacement valves. Titanium prohibited. Hardened keepers permitted. Lash caps prohibited. Valve-diameter tolerance: +.005- inch or -.015-inch from NHRA Specs. The following are prohibited: spark-plug adapters; cylinder-head studs; any grinding in ports or combustion chambers; removal of any flashings; sandblasting or any other modification to cylinder head; any film coating of intake and exhaust runners; any film coating of combustion chamber. Runners and combustion chamber must retain OEM appearance. Final acceptance as determined by NHRA in NHRA’s sole and absolute discretion. Intake side of head may not be cut into any part of valve cover bolt holes. Valve-cover bolt holes must remain unaltered and in their original location. Heat riser passage may be blocked from intake manifold side of cylinder head. Blocking passage down in valve pocket prohibited. The following are permitted: polylocks, jam nuts, screw-in larger-diameter rocker studs or pinned studs, bronze-wall valve guides. Valve spring umbrellas optional. Cylinder head may have all of the seats replaced. Any valve job permitted,O-ringing prohibited. Exhaust plates prohibited. |
#5 | |
Liked 279 Times in 68 Posts
Greg Hill 4171 STK |
Might have been told wrong but was told .250'' total or .125''per side bigger than head of valve was took out, and now could be cut to gasket, this unshrouding has to be done off guide center line as guide and seat machine would cut.
Mike Taylor 3601 |
Refers to max top cut on seat. Thanks.
I was told by more than one tech man that you could do anything in the bowl area as long as it was done with a cutter off the valve guide. Combustion chambers are a different deal.
Liked 10 Times in 6 Posts
Greg, I think you are wrong about using a cutter to cut to the bottom of the bowl, According to division 5 tech director. And It's up to person checking your heads if it's legal and you can't appeal there ruling. Tom
Tom Moock 5704 STK |
