#31 |
Liked 534 Times in 143 Posts
#32 |
Liked 3 Times in 2 Posts
How about any tab weld that broke and the collector fell off?
I have been enhanced enough to go IHRA racing! In response to the above question: Yes, We have had it personally happen on our SC car at a race last year. NOT during the burn out, BUT ON A RUN. Weld Broke on the tabs with bolts holding the collector in place. Collector proceeded to cut rear tire, and be projected out into the field approx. 50 yds. we did get lucky as it broke on the side where the jersey barrier is and not another car, and we were able to stop safely. We have since worked with the header company and "beefed" up the tabs/bolts. Do you currently do inspections on your set up? We do because they are in plain view, and it still happened. Our headers are only 2yrs. old. I dont believe that this rule is a bad one, and I dont know the cost, but dont think for one minute this couldnt happen to you. Debbie Moses |
#33 |
Lelchook just sent me a pair of these.
#34 | |
Liked 34 Times in 12 Posts
#35 | |
#36 |
The tabs will break instantly if you have tire shake. Been there, done that! The only thing holding my collector on was the evac tube. maybe we can get them approved as a tether?
Phil Unruh |
#37 |
Liked 883 Times in 237 Posts
Everyone likes to say they stay on top of things and their stuff will never fall off.
But I've seen many cars at the track and some in my shop have only 1 bolt with no lock nut holding on the collector ,or an old worn out spring, " because I need to be able to take it off to change the trans or converter" I had a baffel from a muffler come out and cut a tire , and that was bad enough. I'd hate to see the damage from a collector . We've all seen this happen at the track, and unfortunately it took someone getting seriously hurt to prompt this rule.
#38 |
I'll just weld my collectors on. I never take them off anyway. Mine does go up on the lift between races anyway, the inspectors have no way of knowing that.
Ed Wright 4156 SS/JA |
#39 |
Liked 6 Times in 2 Posts
It's another knee jerk cover all the basis fix to a very small problem. I've had my collectors held on with springs for 8 years and never had one come off even after smacking the pavement from a wheelstand gone badly. Maybe the spring keeps the tab from breaking, I don't know.
Dale Posnick |
#40 | |
Liked 460 Times in 91 Posts
Bob Bender 144 O/SA 2010-2012 National Record Holder |
