Old 11-12-2013, 11:40 PM   #11
treessavoy
Liked 4 Times in 4 Posts
Default Re: Battery Recomendations
Originally Posted by Mark Ugrich View Post
I've run an Optima yellow top for years. One of the best batteries I've tried, albeit somewhat heavy. It may have been wrong, but I always used a standard charger on it. Never had a problem.
What's the proper way to charge an Optima if not with a standard charger?
JimR
Jim Rountree
Old 11-13-2013, 12:03 AM   #12
SGSST109E
Liked 126 Times in 61 Posts
The key with an Optima battery is the voltage. You don't want the volt. during a charge to exceed 14.5V. You could put 1000 amps thru it and not hurt it, but to high a voltage will. I work for the company that owns Optima. The Optima charger or a Battery tender. I have always used yellow tops in my race car and trailer. I used a Battery Tender 5amp charger. If you charge it over night you will be good to go. If you have an alternator you can race a whole nat. or div. race without touching it. If you use a big sears charger just watch the voltage.
SGSST109E is offline   Reply With Quote
Old 11-13-2013, 12:12 AM   #13
Doug Domm
Liked 84 Times in 21 Posts
Is any charger that is rated for AGM good to use on Optima batteries?
Doug Domm is offline   Reply With Quote
Old 11-13-2013, 12:26 AM   #14
Mark Ugrich
Liked 71 Times in 38 Posts
Originally Posted by Tim H View Post
Likely referring to a slow charge on 2 amp or similar ?
I usually slow charged the week before I went to the track. I don't run an alternator, so there was more than one time between rounds when I'd put the thing on kill until I had a fully charged battery.
Old 11-13-2013, 12:52 AM   #15
2021STK
Liked 17 Times in 14 Posts
With the higher end "S" brand charger I've noticed a voltage creep going beyond the normal 13.2-14V up to and over 16V at times with 2 different chargers. If I catch it, unplug the charger and plug it back in it'll stay at less than 14V from then on. I mentioned this situation to a couple of other racers and they found they had same creeping problem. This also happened on lead acid batteries that I was charging over night and the acid was boiling by morning. Now I won't leave a charger running, only a battery tender. Please stay aware!
Dave Outten
2222 S/SS/SST/SG/HR
2021 S 1968 SS 1969 SR 1966 1990 Bracket
2021STK is offline   Reply With Quote
Old 11-13-2013, 01:57 AM   #16
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
I bought an Optima red top for my gremlin about 6-7 years ago.If I wasn't racing for a few weeks or more I hooked it to a Battery Tender.In the winter it stayed in the car in my trailer hooked to the BT.Eric M.still has it in the car.Keep it trickle charged Eric,it will go for a few more years.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 11-13-2013, 10:05 AM   #17
Rusty Davenport
Liked 101 Times in 27 Posts
Chuck........keep the Honda battery in the front and the regular battery in the rear like it is....better measure those battery boxes before you jump on some of these suggestions.............get the Optima Red Top and forget it.
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 11-13-2013, 03:33 PM   #18
Rory McNeil
I must be a rare exception, I have had great luck with plain old wet batteries, my favorite being a DieHard., although the Interstate in my Mustang has been working great for 5 years. I just put the battery on a 2 amp charge the night before leaving home, and I`m good for the weekend. Both my cars do have functioning alternators. Ans speaking of DieHards, I installed a new 27 series DieHard under the hood on my F350 in May 1999, and the damn things still in there. Even after being parked outside all winter, in the spring it has always started the engine without a charge, although I can`t imagine it can last too much longer.
NHRA 6390 STK
M/S 85 Mustang
Old 11-13-2013, 03:42 PM   #19
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
BATTERIES
Must remain in stock location and be of sufficient capacity to start
car at any time. Second battery permitted if securely mounted in
trunk. Must be automotive type. Both batteries must be same type,
size, and weight. See General Regulations 8:1.
Old 11-13-2013, 03:50 PM   #20
Mark Ugrich
I tried deep cycle marine Die Hard batteries. They would last a year or so. Again this is with no alternator. However when used with an alternator they're hard to beat. All four of my street cars have one. I've had a couple last over 5 years!
