#151 |
Liked 184 Times in 113 Posts
OK...NEW RULE REVISIONS !!
Just got an email from Mike Baker. Asked me to look at the Rule Revisions ! Everything REMAINS the Same !! Cam and Springs ... Lo Mismo !! ( the same in Spanish) ![]() Dan |
#152 | |
Liked 503 Times in 131 Posts
Anyone know if you can squeeze a 15 inch rim over 2010 RT discs? 5 on 4.5 is pretty close to 5-115M. Eric
Eric Merryfield 1883 STK |
#153 |
Liked 51 Times in 3 Posts
#154 |
#155 |
Guest
Posts: n/a
When the rule change out before Christmas I called John at Bullet to inquire about a new cam. I didn't order it at the time but he told me that 5 guys had called that week to have new ones ground. I feel bad for those guys as I'm guessing there is no refund on those.
IHRA should have thought this one out a little longer and asked for some input. Also, I have a hard time believing that many cams are illegal. Look at the times for the PS cars. They aren't going fast enough to have bogus cams. Scott |
#156 |
Liked 322 Times in 110 Posts
Where is NHRA showing spring specs for pressure, and duration and overlap specs for cam?
Mike Taylor 3601 |
#157 | |
#158 | |
Iam helping others get the new cars data added. Not going to be easy but it will get done. As for cams the cam builders are being smart. D |
#159 |
New Cars and New Cams.
Have an idea. Somehow get a list of these new cams. See if the Factories will send the Cam Specs or a Cam to be measured. Contract that effort out to a Cam shop to measure and document. Send the Data to IHRA. Dan |
#160 |
Dan,
specs have to be oem supplied is what I always have been told,and I don't know if you will get any of them to supply specs if it does help them a car. Has NHRA showed specs for duration/over and spring pressure for anything built after 1986 ? Mike Taylor 3601 |
