is there any nice ones for a dually. I would like to see what some of you guys have in your trucks. a tool box with the tank in the bottom is what I am leaning towards.
It needs to look nice . I would want it hooked direct to my fuel system . 2007 duramax pros and cons?? how many extra gallon 50?? 100? |
I use a transfer flow tank in mine came with the truck works great not sure what they cost mine is 75 gal. 02 ford f-350
https://www.transferflow.com/fuel-tanks/in-bed |
Had a guy in Naples, FL build me a custom 90 gallon tank out of .090 aluminum for the GMC Dually for $275.00 complete with baffles.....best move I ever made and had it designed so the roll-top would slide right over it
Rick Blake 2395 SG, SC, SP |
Liked 372 Times in 122 Posts
Phil wish we talked before the weekend. A bud of mine and I were making some and I got one in my dually. Tall and skinny rt at the front of the bed. Push the toolbox back a tad and put er in. 45 extra gallons and it gravity feeds into the stock tank. Its perfect for me. I can go roughly 800 miles towing my LQ w/o a fuel stop. Havent made any in a while but could probably gear up to make a few. Problem is I was using ATP and buying virgin aluminum it was hard to keep the cost down.
$275!! Holy S--t! Musta had leftover materials or something cause the material bill could easily be $275.
#6 | |
Liked 336 Times in 183 Posts
perhaps try a heavy duty truck salvage yard--- they dismantle Semis/buses/vans/straight trucks and you can pick them up in my area a used tank for about a buck a gallon!!!
Liked 21 Times in 6 Posts
Had a PIT Pal on my F550 80 Gal NICE unit
Liked 56 Times in 29 Posts
I also use Transfer Flow, and highly recommend them. Back in the 90s I used a W---gard tank. It cracked and rusted so I went through a lot of fuel filters before giving up on it.
Liked 138 Times in 51 Posts
Darn, too bad I didn't know because I coulda showed you the 60 gal. w/tool box I have in my dually. It's under my topper, but I switched the sliding window around so I can open it at the front and fill the tank through it. But the window does leak some when it rains.
![]() It is gravity feed with a shut-off valve. I believe I read somewhere that you are not suppose to keep it open while on the road per DOT regs. Hope someone can clarify. But I open it at the track and it refills the main tank there. It's great to be able to skip through the higher fuel price states!
LOCOMOTION Racing |
