#371 | |
Liked 7,777 Times in 1,742 Posts
You could just do a Camaro and get both 78 and 81 facias and run both!
#372 |
Liked 780 Times in 194 Posts
'76 Chevelle is an interesting choice. With it you can run the 305 2bbl in U, but also have the option of 350 2bbl, 350 4bbl and 400 4bbl if you decide to make a career with the car. The '75 Chevy II 262 is another option for U.
#373 |
The thing that I don't like about the 75 262 is that it gets the small 2G(1.09vs.1.18). Now if NHRA would give it back all of the HP that the 76 motor has gotten on it well..........
Billy Nees 1188 STK, SS I'm not spending 100K to win 2K Last edited by Billy Nees; 02-06-2014 at 01:33 PM. Reason: brainfart |
#374 |
Liked 12 Times in 4 Posts
Dwight,
I've been talking with Billy about such a combination as I have a near original 1976 Chevelle Laguna S3 in the shop now. Original 305 car
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.” - Aristotle Last edited by Ron Middleton; 02-06-2014 at 02:18 PM. Reason: spelling |
#375 |
#376 |
I thought that there was more of a difference than that(what happens when you ASSume). The Nova was only available with 262 in 75 W/ small carb. I think that I'd rather have the 267 @ 150 HP if I had to take the 1.09 carb, even 165 is too much. 300 lbs. difference in U.
#377 | |
For some reason though, the 1.21 Dual Jet doesn't seem to work as good as the 1.18 2GC ???
#378 |
#379 |
Kinda what I was thinking...Not being an engineer, I don't know if one restriction in a carb over rides the other or vice versa..
Could have something to do with the booster/ venturi cluster being bigger in the Dual Jet...Seeing its part of the bowl casting, you are stuck with it. Take a look at what some of the fast 4 GCs are using...
#380 |
Yes . . . what some are doing.
Back in the day of modifieds, they would use the body of a Holley list 4224 660 cfm carb fitted to an 850 double pumper base plate. The carb body would be reamed from the bottom to match the 1 3/4" size of the throttle bores. Voila! The new "blended" carb would flow in the 750-775 cfm range, but keep the small venturis for crisp throttle response and high quality fuel atomization for under 300 cu in engines. I suspect the difference between a 1.686"/1.093" carb and a 1.686"/1.186" carb would not be as great as one would fear. |
