Old 06-08-2014, 11:42 AM   #1
R. Thorne
Liked 101 Times in 34 Posts
Default gloves for parts washer
Just curious what some of you guys use for hand protection in a parts washer. Have tried nitrile and other throwaway gloves, but they always leak after being exposed to parts cleaning solvent for a period of time. Have a pair of old non throwaway gloves, but they are too bulky and stiff for small parts. Something like the old Playtex living gloves but resistant to parts cleaning solvent? Thanks, Ron.
R. Thorne is offline   Reply With Quote
Old 06-08-2014, 12:23 PM   #2
Painter
Liked 162 Times in 45 Posts
Default Re: gloves for parts washer
Trick I learned a long time ago using the rental parts washers was to put some atf in the fluid every time they changed the fluid. One quart seemed to make a huge difference in how bad the fluid hurts your skin.
Painter is offline   Reply With Quote
Old 06-08-2014, 01:53 PM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
An even better idea is to get rid of the harsh cleaners completely... http://www.napaonline.com/Catalog/Ca...SW8_0006396682
Simple Green is available in several grades and is an excellent replacement as well as being cheaper.
Rich Taylor
I/SA - 321
Old 06-08-2014, 03:34 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Sol-Vex gloves are great, and last forever. Get them at MSC/JL, or cleaning supply companies.
ss3011 is online now   Reply With Quote
Old 06-08-2014, 08:06 PM   #5
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Originally Posted by painter View Post
trick i learned a long time ago using the rental parts washers was to put some atf in the fluid every time they changed the fluid. One quart seemed to make a huge difference in how bad the fluid hurts your skin.
x2
MAURICE BLENDHEIM is offline   Reply With Quote
Old 06-08-2014, 10:30 PM   #6
Liked 5,134 Times in 1,958 Posts
In my case , I don't see adding ATF to the mix from the start, when I'm going to get plenty in there anyway...to the point where the stuff won't air dry on my parts anymore.
But, to each, his own.
Old 06-08-2014, 11:18 PM   #7
HandOverFist
Can't stress enough to the younger fellows...the older folks should know by now. If you are determined to use the caustic solutions you had better be wearing protection...anything that touches the skin is absorbed directly into the body and will take it's toll on you down the road. Good enough reason to swap to less hazardous solutions. Be safe and live to race in your twilight years.
Rich Taylor
I/SA - 321
Old 06-09-2014, 01:06 PM   #8
Jody Lang
Liked 92 Times in 29 Posts
Does the Ozzy Juice stuff work well?
Jody Lang is offline   Reply With Quote
Old 06-09-2014, 01:25 PM   #9
HandOverFist
I have never used it, but it has been adopted by the aircraft industry and we all know how anal they can be lol. That was just one example.
Rich Taylor
I/SA - 321
Old 06-09-2014, 03:51 PM   #10
njk53
The only problem I have had withe Sol-Vex gloves is they don't fit skin tight for small parts.
Nelson Kowal
Stock 345
