Old 08-17-2014, 10:44 AM   #21
Liked 1,880 Times in 422 Posts
Default Re: Crate Motor Pure Stock
The lack of participation has nothing to do with the lack of available and attractive combinations.
Adding even more classes, and another level of difficulty in factoring will not help participation.
Let's leave the economy and expense out of it to for the purposes of this discussion, at least for now.
It is a lack of ambition, attitude, competitiveness, and drive.
Explain any Stock Eliminator class, in either sanctioning body, to most other "racers", who don't know the rules, and watch the look of shock, dismay, and disbelief. Their eyes will glaze over in about 30 seconds. Most of them will then ask you why you are stupid enough to work that hard and spend that much, to go two seconds slower than they do.
For the most part, the vast majority of "racers" today want to be able to buy all the speed they want, without a great degree of difficulty, bolt it together, and go.
That applies especially to the vast majority of the younger crowd.
If they can't buy bigger heads, more cam, more nitrous, or more supercharger, they have no desire to race.
Assemble your Stock Eliminator engine in full and plain view of most of them. The pieces are so boring to them they'll ignore it all after a minute or two, and they won't understand what they see.
The only things that will interest them in a Super Stock engine are the epoxy and welding in the ported heads, and the high end valvetrain.
Old 08-17-2014, 11:46 AM   #22
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Cool Re: Crate Motor Pure Stock
Originally Posted by alan roehrich View Post
the lack of participation has nothing to do with the lack of available and attractive combinations.
Explain any stock eliminator class, in either sanctioning body, to most other "racers", who don't know the rules, and watch the look of shock, dismay, and disbelief. Their eyes will glaze over in about 30 seconds. Most of them will then ask you why you are stupid enough to work that hard and spend that much, to go two seconds slower than they do.
Assemble your stock eliminator engine in full and plain view of most of them. The pieces are so boring to them they'll ignore it all after a minute or two, and they won't understand what they see.
The only things that will interest them in a super stock engine are the epoxy and welding in the ported heads, and the high end valvetrain.
"you nailed it !"
Old 08-17-2014, 11:49 AM   #23
Rory McNeil
I think Alan nailed the mindset of the majority of current drag racer, especially younger ones. If they actually were to build an engine, (instead of buying a turnkey crate motor), chances are it would have a low buck stroker kit and aftermarket heads, and often a "power adder". Look in any ND, ReherMorrison, Schafiroff, or several other big name engine shops can sell you an all aftermarket 700-800 HP engine for less than a typical good Stocker engine. 1000 HP for less than a S/S engine.
Also, it seems that the young guys in our area are not really into actual eliminataion racing. They would much rather pay less entry, get more runs, by entering the "Street Legal" races. When a few have ventured into a weekly ET bracket race, they usually lose 1rst round, and bitch that they don`t get to run anymore that day. And forget about playing with jetting or cam timing, if it won`t net them at least 1/2 second, they couldn`t be bothered. Much easier to add a blue bottle in the truck.
NHRA 6390 STK
M/S 85 Mustang
Old 08-17-2014, 03:53 PM   #24
FINESPLINE
FINESPLINE's Avatar
It is all about the instant gratification desire of the new generation. Nobody wants to hear about working harder on your car. If you cannot write a check, stay on the porch. They want to go fast today, not spending a season flogging a combination.
FINESPLINE is offline   Reply With Quote
Old 08-17-2014, 10:54 PM   #25
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Struck a chord!
Stocked morphed like any class does in all sanction racing even illegal racing.
PureStockRacing.com has two classes.
Pure Stock and other Stock everything better look like Pure Stock but engine rules are very liberal.
The Pure Stock limited Spring Pressure to 130lbs. Cam lift must check on within 1% at .050 and max lift within 2% of original specs and the vacuum at idle must be 16 inches of vacuum.
Btw I am not advocating this!
What I would like to see is to invite PureStockDrags to race IHRA events using their rules. Put them into one of the IHRA Pure Stock classes. Like what was done are the Class Nationals. If they are not competitive change a few rules as the years go by.
They have to make a choice. Use IHRA Rules or PSD rules. Fall under same class that IHRA has for other PSers.
Yeah there would be dual set of rules. But they expressed desire to run IHRA races at the Class Nationals.
