Old 10-23-2014, 10:58 PM   #21
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Fox and SN95 Mustang rear control arms
A couple of rings of soft rubber on the outside and ..ah never mind...I didn't say it.
Lol...in the end it probably wouldnt amount to much if any improvement anyway. I'll just stick to the tried and true cheap routes.
Rich Taylor
I/SA - 321
Old 10-23-2014, 11:16 PM   #22
I tend to agree with you.
That type of suspension does rely on the rubber bushings to keep it from binding as it goes through it's travel. However it's generally accepted that you only need about 1" of separation to plant the tires. You should be able to obtain that much with heim uppers and just a small amount of play in the lower sleeves.
In reality though , I would think all you need in a lower class auto Stocker, is the hard poly type bushing with grease fittings. That kind of set up should last a long time.
I would at least check the lower left one once in a while though.
Old 10-24-2014, 07:48 AM   #23
Dave Gantz
Liked 251 Times in 125 Posts
This guy has some ideas: baselinesuspensions.com
Old 10-24-2014, 08:06 AM   #24
HandOverFist
Here you go Dave... http://www.baselinesuspensions.com/
Rich Taylor
I/SA - 321
Old 10-24-2014, 10:48 AM   #25
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Here is the Baseline Suspensions Outlaw Kit installed on the 8.8, ready to go into my SN95 . Instructions, fit and finish were excellent..
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 10-24-2014, 11:04 AM   #26
HandOverFist
Just ordered the Team Z version... http://www.teamzmotorsports.net/product_p/tzm-uca1.htm
Rich Taylor
I/SA - 321
Old 10-24-2014, 12:05 PM   #27
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Mitch Beri- The Motor City
Old 10-24-2014, 12:27 PM   #28
Chris1529
Liked 70 Times in 29 Posts
Those both look like nice pieces.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 10-24-2014, 12:43 PM   #29
I don't believe you can move pivot points fore and aft in Stock.
Old 10-24-2014, 01:06 PM   #30
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
I saw a 78-79 GM Stocker last year that had a home made setup like that team Z deal.
It was setup to use a shorter upper control arm to change the instant center on the car.
I'm going to read the rulebook again, but I do not remember where it said you cannot change the pivot point of the upper control arm at the rear end.
On the car's body/chassis, yes, you cannot move that, but I am not sure about the rear end attachment point.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
