Liked 325 Times in 50 Posts
I know you know this. Observing old car factors, your humble correspondent has found an interesting thing. The LS1 in the Vette is 345 hp in Stock, and the Camaro is 382. Or 37 HP. Or 333 lbs. 9 x 37. And the GT factor for a full Cambell motor in GT is 313. and a 2004 or 5 or don't have to run FSS or FGT with indexes 2 tenths lower. And I guess these model cars are 30 years older than a Cobra Jet or Drag Pak, no, only 3 or 4 years. Now, I am not a studied person, so Ed, you have to help me. Under this process with my limited understanding a 2008 or 2009 Cobalt or other Jelly Bean can run at 313 factored and be in the regular GT classes which are now at least 2 tenths faster. Maybe I'm wrong. I will look again. I have to look at Super Stock anyway.
Jeff Teuton 4022 STK |
I knew I was in trouble when I saw my name. LOL
I don't spread LS very well any way. My dinosaur is an LT1. Last one was built in 1997. The corvettes do have softer hp factors. Not as many, so of course the triggers not hit so much. The LS1 factors are soft. I know you understand chassis dyno drive Trans losses, my old '98 LS1 Trans Am convertible had an automatic Trans. That is an easy 20% loss. Factory hp rating was 320 (it was the ram air model), with only computer tuning tweaks, at 40000 miles, it made 336 at the tires. Never had a valve cover off, still had the factory spark plugs, fuel filter, and full factory exhaust. If I was running one in GT, I would certainly claim it was from a Corvette. Still, nowhere soft as the Drag Paks. You know that. Right now, it appears Ricky Decker has possibly (other than maybe Jeff Dona) the fastest LT1 (like mine, but faster) in SS. Several told me about seeing Larry Stewart (driving Lloyd's DP) playing with Ricky in the SS/IA class run offs at Indy, year before last. One guy told me he was at the scales when they ran, and it sounded like Larry started whopping the throttle about the 1/8th mile. Larry said "yeah, about there." Surely, Jeff, you aren't 't trying to imply the LS1 is anywhere as bogus soft as the 360" DP? The DP 5.7 Hemi is right behind it. There are other soft combos, but not to that level.
Ed Wright 4156 SS/JA |
That Is A Big Difference In HP For A Corvette That Is Shorther Lighter And More Areo Then A Firebird Or A Camero. I Could See The Difference If It Was A Chevelle Or A Station Waggon!!! Come On NHRA What Is The Reason Behind This!!! This Needs To Be Corrected.
Identical, exact same engine.
Liked 52 Times in 17 Posts
Same problem with the '93 - '97 Lt1 corvettes in stock.
Bernie Cunningham 7053 STK |
Liked 32 Times in 19 Posts
Problem with getting too specific with Hp factoring of a particular BODY style. GT versus SS body maybe ok but seems in stock too specific. Hope it doesn't get to paint colors...
#7 | |
Liked 1,430 Times in 298 Posts
This one is interesting. No one complained when a simple hood change or claiming a different year drastically changed the hp rating on a lot of cars.
James Schaechter 3163 STK Last edited by james schaechter; 11-23-2014 at 12:04 PM. |
#8 | ||
Liked 326 Times in 78 Posts
The LT1 was in 92-96 Corvettes and no 97 in classification guide? Jeff, I think a little 96 Neon 2 dr with a 360 Magnum drag pack engine would be killer, just sayin since you mentioned jelly beans. Could start out in 9.5 lbs. class and still be fast at 8 lbs. Ernie Neal SS 354 yes, I race a jelly bean |
Ernie, you are right, but that combo was surgically removed a couple of weeks ago from GT and put in FGT with a .25 lower index.
Liked 13 Times in 9 Posts
Wrong then, wrong now. The rules are used as much as an excuse to not correct blatantly wrong issues as it is to supposedly govern out-of-line combinations. Even when strictly played by the letter of the rules, politics comes to bear. Common sense plays no part in the system.
