Old 01-12-2015, 09:22 PM   #1
FED 387
Liked 333 Times in 180 Posts
Question J/SA combination???
In a 80 Olds Cutlass what is "the best" engine killer combination for J/SA ?? Chevy or Olds and which engine to be a virtual record setting combination?? FED 387
Old 01-13-2015, 01:42 AM   #2
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: J/SA combination???
Olds 350.
However, you will need to change the grill to the 442 version with square headlights unless the car is a 442 model already.
Old 01-13-2015, 12:28 PM   #3
Lyn Smith
Liked 973 Times in 195 Posts
I have a real nice solid 1980 buick regal limited for sale.Would make a great stocker and can use the olds ,and chevrolet engines.
Old 01-13-2015, 01:38 PM   #4
Rick Schilling
Liked 14 Times in 10 Posts
Olds 350.
I tend to agree with the Olds 350, however I believe it might be the more difficult build (and more expensive), not to mention probably having less market value than the Chevy in the end.
I'm not really sold on the reliability of the 77-80 Olds 350 engine either. The cylinder head castings are lightweights and notorious for cracking as well as the "windowed" lightweight blocks for failing. An earlier year block can be substituted but the head bolts are a different diameter and modifications have to be made.
On the other hand, Don Forester always ran very well with the Olds 350 and in a variety of body styles to boot.
I think it could be made to work, just not easily. That, however, can make the potential reward all the more gratifying!
Rick Schilling is offline   Reply With Quote
Old 01-13-2015, 03:44 PM   #5
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: J/SA combination???
FED 387,
I would say the best combo for the money is the 305ci Chevy @ 235HP vs the Olds 307ci @ 250HP... Check it out on Dwight Southland Class Racer site, gives you all the answers... Good Luck & Welcome !!!
Dave Ribeiro 1033 STK
Old 01-14-2015, 11:41 AM   #6
SSDiv6
Originally Posted by Dave Ribeiro View Post
FED 387,
With a 1980 Olds you can run the Olds 350 which will be all over the Chevy 305 and Olds 307.
Old 01-14-2015, 01:10 PM   #7
Liked 5,121 Times in 1,952 Posts
258 hp vs 275
.474 lift vs .400
800 cfm vs 750
What was the question again?
Old 01-15-2015, 09:14 AM   #8
SSDiv6
258 hp vs 275
.474 lift vs .400
800 cfm vs 750
Mark, you forgot the additional 45 CID.
