Old 05-05-2015, 08:25 AM   #11
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: Radial Slicks Moving On Rim
It may take a few more passes to "set" the tires. keep trying..
I run the exact same #'s and slicks, rim size as you. I have no slippage...
Old 05-05-2015, 12:03 PM   #12
Mike Delahanty
Mike Delahanty's Avatar
Liked 276 Times in 54 Posts
I'm on my 5 or 6th set of Hoosier Radials and have never had an issue. For curiosity, I put a paint mark on the tire that aligns with the valve stem on the last set. After about 70 runs you can see how much they have moved - not much at all. For the record - this is a 3400 LB A/SA Max-Wedge 64 Plymouth - mounted on 10" Weld Wheels w/ no special work on the bead - no adhesives - but always run with 21+ pounds of air pressure.
As referenced by others, I think the wheel width and higher air pressure are the key.
Name:	Hoosier Radial.jpg
Old 05-05-2015, 08:28 PM   #13
George Mirza
I've had this same issue for years. Tires would rotate 1/2"-1" on every pass. Hoosier 30x9, 10" wheel, 20lbs of air 3200 lb car. Swapped tires from side to side and they would move back to a point, sometimes one and not the other. Tried screws, then the tires would move and leak. My next move is to scuff up the bead area of the wheels, give the tire bead something to bite on. Sandblasting suggestion is a good one, I was thinking DA and 180 grit paper.
George Mirza is offline   Reply With Quote
Old 05-06-2015, 04:52 PM   #14
1700camaro
Liked 226 Times in 115 Posts
Originally Posted by j gardiner View Post
We're their any adverse effects from the slicks moving on the rim.
No out of balance issue yet. Going to break the beads & re-index to where they were initially balanced at.
I haven't tried over 20 lbs. air pressure yet. Might try 21, but they are crowning pretty good at 20 with that 8" rim.
1700camaro is offline   Reply With Quote
Old 05-06-2015, 05:33 PM   #15
Ed Wright
Ed Wright's Avatar
That is why they should be on 10" wheels. They will hook harder, and run faster with more air.
Ed Wright 4156 SS/JA
Old 05-06-2015, 06:29 PM   #16
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
agree!!!
Old 05-06-2015, 06:33 PM   #17
supergas4
Liked 6 Times in 5 Posts
If wheels are very old that could be a problem.Every time you have tires mounted the wheel changes very little but it does change.I have been mounting slicks for 35 years the older the wheels the easier the comeoff and go on.I use the spray permetex.Radials allways like more air than you would think.Dwight Allen
supergas4 is offline   Reply With Quote
Old 05-06-2015, 07:52 PM   #18
1700camaro
They were bought in early 1989 & have had many tires mounted on them.
Old 05-08-2015, 09:08 PM   #19
j gardiner
Liked 55 Times in 29 Posts
Most everybody I know don't even check to see if the tires move. Just put the on and let them eat. Maybe I am just lucky idk. It might not be any big deal if they move a little bit.
j gardiner is offline   Reply With Quote
Old 05-10-2015, 01:46 PM   #20
1700camaro
My main concern is the tire/rim balance!
