Liked 58 Times in 23 Posts
we have a J/SA ,255hp 69 Chevelle wagon, Does anyone have the part number of the 1/4 inch base gaskets for a Quadura jet ? Thanks
Liked 81 Times in 23 Posts
Fel Pro 17845 is one option.
Liked 28 Times in 9 Posts
Jegs/Summit has most of the Fel Pro numbers ; I use #1908 .
Also look up Chryco Q'jet base gaskets.
old 1608 stock racer |
Liked 197 Times in 32 Posts
I have always been under the impression that rule book called out "maximum two 1/4" carb base gaskets"? I was told by reputable long time stock racer that its just two gaskets with no specific thickness! Not sure it make any big difference but dose anyone have clarity?
Jim |
i use a couple fel pro 60335 gaskets
#7 | |
Liked 1,059 Times in 376 Posts
Bought theses off Mike Keown many years ago. They are 1/4 inch thick
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 08-18-2015 at 02:39 PM. |
Jeff, I think that open style gasket is OK for a open plenum intake manifold,, but on a stocker cast manifold, it should be a 4 hole , shouldn't ?
For what its worth, several years ago we tested with the open gasket vs. the 4 hole gasket on the dyno and the 4 hole gasket made slightly more power and torque with our combination.
Nelson Kowal Stock 345 |
