Old 09-16-2015, 04:50 PM   #11
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Default Re: Stock Elem Crankshafts??
OK, why would you need a forged crank in a 305? I would imagine the RPM level would not need a forged unit? Some people are surprised that I used a real 396 block for my 396/325 as opposed to a sleeved 454. Plus it is only a 2 bolt main. Yes I do have steel crank in it, Motor has been up to 7300, but loses power over 6400 so I don't need to go there.Made over 100 passes on that motor. Is that the same deal with those 305's ?
Remember the sreet, musclecar car show days "I have a 4 bolt main block too"
Could I dare to say sometimes we can over engineer something when it does not need it.
My buddy has run Comp for years, and yea, 10,100 RPMs big difference from a Stocker motor. Checking Valve springs after every pass, tear the motor down during week, ect.
Will Lamprecht I/SA in progess 396/325
Old 09-16-2015, 08:59 PM   #12
nolongerracing
Liked 72 Times in 27 Posts
Wait a week or so... there will be a couple of 3.480 stroke cast cranks (1 Scat and 1 Eagle) added to the approved list.
nolongerracing is offline   Reply With Quote
Old 09-17-2015, 09:58 AM   #13
GregP
Not really sure it is a absolutly needed item but I hate to destroy a engine by cutting corners. I am sure it would hold up but I had just rather not chance it.
GregP is offline   Reply With Quote
Old 09-17-2015, 10:01 AM   #14
GregP
What about forged, they are plenty of cast out there..
Old 09-17-2015, 09:17 PM   #15
nolongerracing
400 HP, 7000 RPM, why would you put a heavier forged crank in a 305 stocker. Waste your money where you want to. I've seen many 350 SuperStock engines run a 30 year old cast crank 600 HP and 8500 RPM.
Old 09-17-2015, 11:09 PM   #16
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: Stock Elem Crankshafts??
I remember the aftermath of a 350 stocker motor that broke a crank,several rods, the windage tray and the pan when the cast crank broke.I also worked with a guy who was rebuilding the good 427 in his boat,but while that engine was down, he put a cast crank stock rod 402 in it with the big roller cam,heads,pan and the tunnel ram from the big motor, and went out. While hot dogging it, it blew up,and the next week at work he brought in a bag.In it were two mangled rods, one crank pin,and part of a piston. It broke on both ends of the same crank pin, and the pin and rods went through the pan and necessitated a fiberglass repair on the hull to fix a leak. I'm scared of cast cranks,but some people use them without incident. Good luck,I guess.
Old 09-18-2015, 08:57 AM   #17
James Perrone
Liked 1,823 Times in 426 Posts
if it didn't come with a steel crank you can not use one.. good luck with that
james perrone 1290 STK
James Perrone is online now   Reply With Quote
Old 09-18-2015, 09:05 AM   #18
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
James, why do you say that? I see no ruling that states that, and there are lots of instances of engines that were not produced with forged or cast cranks running either.
Old 09-18-2015, 01:44 PM   #19
Liked 1,829 Times in 414 Posts
The flip side of that question would be "why hunt a 30 year old junk yard piece, or more likely 4-5 to get a good one, then spend $500+ on prepping a $20 30 year old junk yard part?" He could simply order a new crankshaft, with the stroke and index already correct, and never have to hunt an old junk yard part or worry about it again.
Old 09-18-2015, 02:12 PM   #20
Greg Reimer 7376
I think that about most concisely sums it up.
