#11 |
Liked 187 Times in 58 Posts
Every time the subject of roller lifters for stock, someone suggest running Superstock ,It appears that there were a number of gentleman that wanted these changes over the past 30 years, Aftermarket Heads, Intake, Pistons ,Push Rods, Valves, Camshaft, Valve Springs, Retainers, Connecting Rods, Piston Rings, Crank Shaft, Engine Block, Oil Pan, Lifters, Roller Rockers, etc., Aftermarket parts have helped every body in stock eliminator achieve performance gains as well as durability along with a alternative to in some cases 50 year old OEM parts . Who will be the first to go back to the OEM parts and get run over (Flattened) or worse have their engine explode !
John Ancona 717 STK / SS |
#12 | |
Liked 5,145 Times in 1,964 Posts
So they need to be coated then ,too? ...Further making my point.
#13 |
Liked 184 Times in 113 Posts
From the comments, glad running Pure Stock...!
Lot of racers having a tough time with 8000rpm flat tappet hydraulic lifters. What about a limit on Valve Spring Pressure. Saying that! What would make common sense? or Should racers be doing that anyway? Dan |
#14 |
Liked 325 Times in 50 Posts
OK, roller rockers, any spring, almost any cam, any valve job, any anything, but lets keep them old lifters and let everyone buy 1200 bucks tool steel lifters instead of a hydraulic roller conversion for about a quarter. I already got mine. I want everyone to share in the treasure.
Jeff Teuton 4022 STK |
#15 |
Liked 905 Times in 193 Posts
There hasn't been too much "stock" about Stock Eliminator for quite a while now. Jus sayin'...
Bob Don 128 SS |
#16 |
Liked 783 Times in 195 Posts
Limiting valve spring pressure makes way too much sense and is way too simple. Let's gouge on everybody some more.
#17 |
Liked 7,854 Times in 1,750 Posts
^^^^^^^^^^^^^^What Dwight Said!^^^^^^^^^^^^^^^^
#18 |
Liked 319 Times in 68 Posts
Dwight's right. I made my LT-1 stocker in to a super stocker two years ago, sure the initial investment was a bit, but only about two or three thousand dollars more than my last stocker engine. I just freshened it and it was cheaper than freshening the stocker engine.
Lee Valentine 1661 STK |
#19 |
Liked 4 Times in 1 Post
how about quick fuel carburetors for my mopar the chevy have them and holley still makes the replancement 4 corner idle better metering blocks better boosters and more
#20 |
Liked 2,753 Times in 974 Posts
All this, and no battery in the trunk.
