#41 |
Liked 184 Times in 113 Posts
Going to Roller Cams.
The racers will have new geometry to play with. More Spring, Duration and new level of breakage. Roller Cams will yield higher rpm. Leading to more and impressive dramatic catastrophic failure! Need a spring limit rule to back off from limits of material science. D |
#42 |
Liked 7,717 Times in 1,738 Posts
Was the study on this done by the GAO?
#43 |
Liked 799 Times in 236 Posts
If the GAO had done it, we would 'save' money by raising taxes to cover the 'savings'.
![]() Just comparing the difference in component prices. ![]()
"That'll never work....." |
#44 |
Every time the NHRA makes a change to Stock Eliminator Racing to make it cheaper to get parts, easier on parts, easier to get parts, easier to tech,etc,etc,etc, they don't look down the road at what the residuals will cost! And I don't believe that they care either!
#45 | |
#46 |
#47 | |
Liked 8 Times in 7 Posts
without losers,winning means nothing. |
#48 |
Guest
Posts: n/a
Want to make racing cheaper? Fold up stock, anybody who wants a cheaper easier racing just run Super Stock. You can buy all the best parts your heart desires.
For the rest, bracket racing is alive and well in the rest of the country. You can run an engine that will last for 100's of runs If your blowing up valve train parts, chances are something is off in your valvetrain combo. To aggressive of a camshaft, wrong geometry, running the engine to high in the rpm range, ect. Time to work on your combinatio. Go find somebody with a spin tron and start testing parts, talk to your engine builder about a solution. It isn't always about buying better parts to solve a problem, its about finding the right combo for the ones you have. Guys with LS engines in new Camaros were having trouble with ROLLER lifters. Just ask Dan Fletcher, he is one of the guys that come to mind. Roller lifters break all the time, remember that. Keep changing rules in stock to parallel us to Super Stock, when they get rid of our class in a couple of years then the ones who cant or dont want to afford a full blown SS can just go away quietly. Would be better for our wallets for sure. |
#49 |
Guest
Posts: n/a
I thought roller rockers were going to fix everything?
#50 | |
Liked 1,820 Times in 425 Posts
james perrone 1290 STK |
