Old 03-21-2016, 08:14 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default SBC EFI fuel rails
I am in need of SBC EFI fuel rails that have conventional SBC port spacing with #10 AN O ring threads at each end
Larry Woodfin 471W
Old 03-21-2016, 09:16 PM   #2
Dragsinger
Default Re: SBC EFI fuel rails
Edelbrock #3630 has 3/8 pipe thread so I can use adapters to #10 AN.
That is the best option I see so far
Larry Woodfin 471W
Old 03-21-2016, 09:35 PM   #3
Dragsinger
this shows a factory fuel rail test fit. It does not have enough material to thread 3/8" pipe.
ID:	33082   Click image for larger version
Larry Woodfin 471W
Old 03-21-2016, 09:43 PM   #4
Ed Wright
Ed Wright's Avatar
This your Super Stock engine? If so, why would you need -10 lines?
Ed Wright 4156 SS/JA
Old 03-21-2016, 10:02 PM   #5
Dragsinger
Ed,
it is our 417" SBC bracket engine.
Fuel cell, fuel filter, fuel pump, fuel regulator all #10
Holley EFI system
ID:	33084   Click image for larger version
ID:	33085   Click image for larger version
Larry Woodfin 471W
Old 03-21-2016, 10:05 PM   #6
Dragsinger
Ed,
we are definitely form one extreme to the other. With the Super 10 I am installing a 4GC
Larry Woodfin 471W
Old 03-21-2016, 10:57 PM   #7
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
Not sure it will help...
What about a weld on fitting? That is how I did mine this last go around...
http://www.locashdyno.com/store2/ind...roducts_id=324
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 03-21-2016, 11:16 PM   #8
FED 387
Liked 333 Times in 180 Posts
Larry --check your emails good contact info Dick
