Old 12-07-2007, 09:47 PM   #11
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: Any valve job????
tom:you went 10.80 on a amc 20 ,man ,the model 20 blew up two times of coarse it was a stick car,the model 20 is an afficaint rear dana 60 is strong but heavy, 8 3/4 should be about the same and i now alot of guys make it work in high horse power situations , gmonde
Old 12-08-2007, 01:25 PM   #12
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Unfortunately the 69 factory Hurst AMX has a factor of 7.49# , Just enough to keep it out of AA/S. Unless you can adjust down 1 class with it. .................... Of course you would have to find someone at the New Chrysler Corp. who would push it thru to NHRA, since it was only a 50 unit car! .... I dont know if a car that is an accepted 50 unit combo in Super Stock is automaticaly accepted in Stock. ...... Tom
Old 12-09-2007, 03:49 PM   #13
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
I believe that if you really look at the specs on that engine(1969 390/340 AMC) , it will pretty much be a no-go for AA/S anyway (at 407 hp).
Old 12-09-2007, 05:39 PM   #14
Speedracer
You must use the 45 degree seat angle.
Speedracer is offline   Reply With Quote
Old 12-09-2007, 07:47 PM   #15
Tom Goldman
Dwight, I'd think the Crane fully ported heads would be another stumbling block, Altho they are pretty tame compared to what it would be up against. ....Just an outloud daydream. ........Tom
