Old 06-01-2016, 11:23 AM   #1
henrys57wagon
henrys57wagon's Avatar
Default Dwyer gauge
There is some talk of using a Dwyer gauge
. What model number is the one you use? I looked on the website but did not know what I was looking for. Thanks.
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
Old 06-01-2016, 07:18 PM   #2
Kevin Panzino
Kevin Panzino's Avatar
Liked 759 Times in 139 Posts
Default Re: Dwyer gauge
Henry, a Dwyer Model # RMC-121 is a good choice.
10" tall and a 1 to 10 CFM flow rate. Its around $100.
Old 06-01-2016, 09:39 PM   #3
henrys57wagon
Thanks Kevin. Boy oh boy the more I read these posts the more I don't know.
Old 06-02-2016, 08:26 PM   #4
richie 2
Liked 205 Times in 93 Posts
and what is the purpose of this tester? henry it comes with old age.
Old 06-02-2016, 10:23 PM   #5
Liked 1,892 Times in 423 Posts
To measure blow by on the dyno.
Old 06-03-2016, 12:14 PM   #6
henrys57wagon
Can it be used in car off dyno?
Old 06-03-2016, 12:25 PM   #7
That isn't really practical, if it is even possible. It has to be mounted perfectly vertical, and it uses a steel ball to measure flow, so you'd have various G forces acting on it, preventing it from working correctly. Its pretty much a dyno only device. There are some "blow by" or "crankcase pressure" sensors on the market, but they're not cheap.
Old 06-03-2016, 02:11 PM   #8
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Has anyone used any of the electronic gauges that are on the market?
Old 06-03-2016, 02:46 PM   #9
V M Kauffman
The one I used was a Fisher-Porter same one Chryser Race Group used was about $300.00 30 years ago. I could hook it up as Alan described and if it was bad enough the weight in tube would bounce just spinning on starter. We would check engine every time we loaded car to come home by hooking up meter and just free rev engine to 6500 rpm if Blowby was over 2 cfm engine would come apart we we got home. Difference on a 740 hp engine on dyno at 6 cfm down was down 60 hp to 1 1/2 cfm. Ted Flack showed us how to use it. When Chrysler tested at the race track they used the meter on all wet sump vehicles. Sometimes it was actually mounted in the Vehicle.
V M Kauffman is offline   Reply With Quote
Old 06-04-2016, 07:35 AM   #10
Dave Gantz
Liked 251 Times in 125 Posts
Is a Dwyer gauge the same as a manometer? I made one years ago for use in testing outdoor power equipment engines.
Maybe it's not precise enough in this case, but here's one similar to the one I made:
http://www.obairlann.net/reaper/moto...manometer.html
