Old 12-13-2016, 10:49 PM   #1
herbjr
Liked 83 Times in 32 Posts
Default R5 Dodge Engine for SS Modified
SInce the R5 Dodge Nascar engine has a chevy bolt pattern on the back of the block and crank and the Drag Packs come with a Powerglide, Can I run a Powerglide transmission with that engine? This is for SS/BM-SS/DM
I could use a jeep trans which is a 999 chrysler with a chevy bolt pattern in the 70's
Asking for a friend.
Herb McCandless Jr
herbjr is offline   Reply With Quote
Old 12-13-2016, 11:00 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: R5 Dodge Engine for SS Modified
I believe in a modified you can run any auto trans. lots of guys running Chrysler tranny's with ultra bells behind Chevy's.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-13-2016, 11:21 PM   #3
herbjr
I'm out of the loop on SS Modified stuff for sure, been racing Juniors for 10 years.
Old 12-14-2016, 12:04 AM   #4
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
904 Chrysler or 727 with 904 innerd....Pro Trans for sure. Contact Dave or Darren. IMO, Don't waste your time and money with less. Almost 2 tenths for me from a good aluminum 727.
Old 12-14-2016, 02:05 AM   #5
Rick Pike
Herb McCandless Jr
I run a Pro Trans in SS/FM and it was originally in a Chrysler case.
Changed to GM a few years back when they allowed 3 speeds in lieu
of those which only came with 2 speeds - for SS/NA, SS/MA
Regardless of case, run the Best, a 3 speed Pro Trans.
Rick Pike is offline   Reply With Quote
Old 12-16-2016, 01:44 PM   #6
340Cuda
Liked 804 Times in 341 Posts
Herb McCandless Jr
I he goes this route I have a re-certified CSI shield for one that I will never need.
Thanks,
Bill
Old 12-17-2016, 05:11 AM   #7
Adger Smith
Liked 880 Times in 311 Posts
Herb, Jr
I have run a 904 Proflite in SS/DS. behind a Chevy V-6. I think the Tranny rule in any modified class is pretty open.
Adger Smith (Former SS)
Old 12-17-2016, 02:00 PM   #8
Rick Leininger Jr.
Herb McCandless Jr
The bellhousing pattern in the back of the block is not Chevy, the pattern doesn't match up to any automatic that I know of. ATI, Kowalsky Racing, etc.. make an adapter, or a mid-mount can be fabricated to adapt. Some crankshafts are Chevy pattern, some are Ford, some were altogether different (Penske). You already have a class in mind, but I think with the R5 block layout they would make a killer SS/AS combo.
Rick Leininger Jr. is offline   Reply With Quote
Old 12-18-2016, 10:15 AM   #9
Frank Castros
Call Wes Leopold Jr. at Arlington Auto Body in Pittsburgh PA. and he'll set you straight.
Old 12-18-2016, 06:11 PM   #10
71mavlouisville
71mavlouisville's Avatar
Liked 28 Times in 1 Post
I am not familiar with the R5. Does it have the standard bore spacing of a small block mopar? I think the standard bore spacing must be retained.
Ashton Hudson SS/CS 4373
71mavlouisville is offline   Reply With Quote
