#11 |
Liked 1,935 Times in 582 Posts
Racing seats can save quite a bit. Lithium battery will save at least 40 lbs on the nose of a stocker.
Mike Pearson 2485 SS |
#12 | |
Liked 115 Times in 35 Posts
#13 |
Liked 780 Times in 194 Posts
The '67 subframe legend was started to cover up some chemically milled parts. If the aura of "unique" parts is attached to some identifying factor, people tend to not look at other possibilities. Hence, the '67 6 cylinder subframes, the 520 "T" heads, etc.
#14 |
Liked 319 Times in 82 Posts
Is there anybody still chemical milling parts??
#15 |
Liked 1,826 Times in 426 Posts
Once you have changed out brakes battery and other bolt in components you need to search in every where in the car and remove any little thing . A pound here and there adds up not easy but I can get my nova to the Fsa minimum 200 lb driver. Every little bit counts.
james perrone 1290 STK |
#16 |
Liked 58 Times in 23 Posts
I know this is an old post . As James mentioned , its surprising what things weigh... I had Moroso chrome valve covers and the fancy steel hold downs, the covers alone where over 9 pounds each .
#17 |
Liked 162 Times in 45 Posts
James, I need a little ballast to E weght with a 295 motor with my 225 but in the seat. If people cant get their car to minimum they havnt worked and cleaned hard enough.
#18 |
Liked 166 Times in 71 Posts
You don't need to ad 310, you need to move 75-100 to get where you want, maybe even less if its in the right spots
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
