Old 06-12-2017, 07:52 PM   #1
richie 2
Liked 205 Times in 93 Posts
Default oil/water
bbc got some water leaking at the intake...milk shake time. any way to aid getting back to normal...bunch of oil changes? tks
Old 06-12-2017, 08:57 PM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: oil/water
Took me about 3 cheap 5-quart jugs of Walmart SuperTech oil. Run briefly, drain, repeat until it looks like oil coming back out.
S/ST 51
S/C 53
Old 06-12-2017, 10:00 PM   #3
Kris Kristofferson
Kris Kristofferson's Avatar
Thanks Mr.Evans and Class Racer gurus!
I guess the tricky thing is we are also trying to break in a big flat tappet cam at the same time.I also have this gunk stuff to help clean out the system . What about using a very good break in oil (AMSOIL), and the gunk combo as a "2 part deal" ? here are some pics...
Name:	DSC03556 (Medium).JPG
ID:	40464   Click image for larger version
Name:	DSC03558 (Medium).JPG
Kris Kristofferson is offline   Reply With Quote
Old 06-13-2017, 08:58 AM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Leave the intake off and put a heater under the oil pan and let it run for a while and most of the moisture will dissipate. Might not get it all but will help
Mike Pearson 2485 SS
Old 06-13-2017, 11:23 AM   #5
dlee
Liked 9 Times in 4 Posts
Did you replace oil filter each time, or drain the filter & re-use?
dlee is offline   Reply With Quote
Old 06-13-2017, 01:57 PM   #6
richie 2
new filters used
Old 06-13-2017, 02:53 PM   #7
Bobby DiDomenico
Liked 101 Times in 52 Posts
Mike has a great plan. If you can get the pan off, place the pickup tube in fresh oil and manually run the pump pushing fresh oil through the passages. Just remember to have a large catch pan underneath!
Old 06-13-2017, 04:38 PM   #8
richie 2
do any of the engine oiler pre/lube deals use a separate resiviour that you could pump fresh oil through the system and into the empty oil pan...then just drain it?
Old 06-14-2017, 09:43 AM   #9
dlee
new filters used
Thanks
