Old 08-17-2017, 02:56 PM   #71
Coleydog
Liked 53 Times in 38 Posts
Default Re: New A/SA In Minnesota
Originally Posted by Rob Wright View Post
Are you saying the AHFS is not effective?
Let's suppose all the factories got together & gave NHRA a billion dollars to allow their 500 HP cars to run with a 100 HP rating.
Would racers with the 100 HP-rated cars get penalized for running too far under the index on average and on the spot if it is really extreme?
I'm still trying to understand why HP ratings are a problem, since they have always been grossly underrated since at least the early to mid-sixties and the NHRA has the AHFS in place to balance out the playing field.
Pretty sure after 50 years NHRA know what the early engines are capable of, maybe not so with the new ones yet and the AHFS only works at 1320 ft not 1000.
Old 08-17-2017, 03:05 PM   #72
GUMP
Liked 2,354 Times in 554 Posts
Originally Posted by Greg Hill View Post
That motor would make probably 100hp more than Larry's old 440!
The one that got a HP reduction and wins class all over the place? (no offense Larry. You know I love Ya)
Old 08-17-2017, 03:30 PM   #73
my69396
Liked 46 Times in 20 Posts
That is what I was talking about. The body in white cars/ wrecks built as a stocker/super stocker is what I meant not vin numbered cars. I know of some fords that were body in white or wrecks that were made into cobra jet cars but they didn't have the rear axle issue. But on a GM car and the drag pack cars they have a rear axle issue if they aren't made that way ie COPO factory drag pack. But that is just my thinking.
my69396 is online now   Reply With Quote
Old 08-17-2017, 03:40 PM   #74
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
As I understand it, ALL 2008 and later cars can run a 9" rear end, IRS can be replaced with hard axle. Moser will sell you the approved kit if you want.
Pedigo Perf is offline   Reply With Quote
Old 08-18-2017, 08:15 AM   #75
Rob Wright
Liked 21 Times in 7 Posts
So if he races to the 1000' mark, does that make him more consistent to his dial-in?
And if he decides to stay in it to the 1320' on his 1000' dial-in, will he win?
I suppose the answer is "yes" if he's running class, but then he stands a chance of getting HP added if he runs too far under his index. Correct?
Rob Wright is offline   Reply With Quote
Old 08-18-2017, 10:20 AM   #76
Coleydog
Since day one it's called sand bagging, done in every kind of sport and enterprise. IMO when you see someone bury the record they're either not thinkng or trying to drum up business (that engine flies, I want one).
Mike
Old 08-18-2017, 10:30 AM   #77
Rob Wright
Mike
So you agree then that it really does not impact guys with older cars if a guy with a newer car buries the record & gets HP piled all over himself?
Old 08-18-2017, 12:20 PM   #78
junior barns
Liked 20 Times in 14 Posts
NEW OR OLD doesn't matter!! If a car goes stupid fast whether it's in really good air or not it should get hit!! Just look at the car that went 9.98 in D/SA! So what will it go at indy, 10.15??
junior barns is offline   Reply With Quote
Old 08-18-2017, 12:25 PM   #79
junior barns
The car or cars in question should be bad fast !! I'm sure Mr Sherman will make who ever comes, show all they got!!
Old 08-18-2017, 12:43 PM   #80
Jeff Teuton
Liked 325 Times in 50 Posts
J. Allen. Jump in here and stir this pot. Need a big spoon.
Jeff Teuton 4022 STK
