Liked 13 Times in 11 Posts
On my street driven 69 Chevelle with a 496 ( plenty of power ) I don't want the kick down functioning.
I've already disconnected the kick down solenoid , now I apparently still have "modulated" kick down function. How can I completely disable the kick down? Thanks in advance. |
#2 | |
Liked 68 Times in 41 Posts
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
Why don't you call a local transmission shop?
Ed Wright 4156 SS/JA |
Did you try screwing the modulator adjustment in?
Might have to screw it out, then re-work the governor, now that I think about it. Not your normal S/SS question, Joe.
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 11-25-2017 at 12:13 AM. |
Because.....its Fri. night , its 10:30 and I want to know , now.
The modulator and "kick down" function isn't so clear to me.....I wanted to delay the 1-2 shift so I increased modulator tension , to solve that. Now how all this relates to eliminating downshift / kick down......I have no clue. |
#7 | |
Find the 3-2 valve and block it so it won't move. 2-3 should work fine with absence of gov. and mod. pressure for downshifts after slowing.
Liked 886 Times in 238 Posts
Like Mark said just block the 3-2 downshift valve.
Small valve at bottom right of photo . I use a piece of 3/16" brake tubing ,about7/8" long , file it for a final fit . Been doing this for years ,works great .
Thanks guys.......in this view is the mod present? Where is the tubing?
Sorry ,been off line for a while ,Damn Work ! No it is not shown in the picture . You substitute it in place of the spring .
When I get home , I have a good picture of it I'll post.
