Old 10-30-2018, 01:38 PM   #1
Lyn Smith
Liked 994 Times in 200 Posts
Default Stuck carb Jet
Got a Jet in a carb bowl that just wont budge.Tried soaking it in penetrating fluid,a little heat from a heat gun etc. No luck.
Lyn Smith is online now   Reply With Quote
Old 10-30-2018, 02:29 PM   #2
Mike Jones
Liked 684 Times in 289 Posts
Default Re: Stuck carb Jet
You might try "shocking" the threads with a punch and hammer, if you can get to it. Not too hard
Old 10-30-2018, 02:31 PM   #3
...Or an impact driver with a long tip on it.
Old 10-30-2018, 03:02 PM   #4
Makinchips
Put it in a pot of hot water on the stove. Do this when the wife isn't home.
Makinchips is offline   Reply With Quote
Old 10-30-2018, 04:09 PM   #5
ron mattson
Liked 68 Times in 31 Posts
Spray it with Minnesota fast freeze from
Goodson, it’s a freezing spray that will shrink the jet
Could warm the carb body then do it should
Make for easy removal.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 10-30-2018, 06:44 PM   #6
71lemans
Lyn, let us know the results. I have tossed a couple of carbs for issues like this.
71lemans is offline   Reply With Quote
Old 10-30-2018, 07:37 PM   #7
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
You can try an impact driver,don't whack it too hard or it may crack the main body.If that does not work,the slot on the soft brass jet will be mutilated.The other option would be to drill out the jet and use a small e-z out with a T-handle to remove it.Good Luck!... gsa612
Old 10-30-2018, 07:49 PM   #8
DODGEBOY
Liked 4 Times in 1 Post
try reverse drill bit start smaller then hole
DODGEBOY is offline   Reply With Quote
Old 10-30-2018, 08:16 PM   #9
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
I agree, use a left hand bit , but you may want to do this on a Bridgeport Mill to get the drill exactly on center with the jet . If the jet doesn't bite and twist out , then drill it out and retap it , if you can't pick out what is left of the jets threads . leave the carb setup in the Mill so everything stays lined up . Use the chuck to align the tap . Left hand bit needs to be the size that would allow you to tap that thread size .
Old 10-31-2018, 12:29 AM   #10
Dissident
Liked 73 Times in 36 Posts
Mr Smith et al,
I have run across a lot of these type stuck jets from some over zealous dude overtightening the jet(s). Whenever I can't get the impact tool approach to work, I just drill the jet and use an appropriate sized (#2 or #3) ezy out tool. That method has always worked and I always run a tap through the threads afterwards. Of course it ruins the jet, but new jets are cheap compared to losing a carb casting through hammer and tong approaches.
Jets shouldn't be tightened to much more than about 40 inch-pounds anyway.
Hope that helps solve the problem for you. Good luck.
Regards,
HB2
Dissident is offline   Reply With Quote
