Liked 205 Times in 93 Posts
r they worth the time & investment ? tks
Liked 3,181 Times in 972 Posts
With what combination? Makes a difference...
Liked 532 Times in 109 Posts
If your car has a tendency to break bellhousings, yes. I would recommend taking the trans case to a competent machinist so it can be cut and the bell housing be registered so that it can be installed properly.
Jim Kaekel 3836 STK |
Liked 271 Times in 107 Posts
I wouldn't pull my trans out just to put one on , but if it's already out,its a no brainer,,considering the cost.
Liked 7,939 Times in 1,520 Posts
There is absolutely NO need to install a ultra bell on your tranny...UNLESS you are cracking the case. After you have cracked ONE case,...it’s a lifesaver....of course my ole buddy Captain Jack cracked 2 cases before he bought the bell.....
thankyou !!!
Liked 1,931 Times in 580 Posts
Its the best way to go if you are in a class that requires a guard on the flywheel/ Bell housing. I have done several on Powerglides and they work real well.
Mike Pearson 2485 SS |
Liked 52 Times in 32 Posts
If you use a Bell that is easily removed and sent back for recert and a good quality Trans blanket, you'll save much $$ and frustration.....Worked for me!!
Liked 133 Times in 76 Posts
They are nice and strong but they are also thicker and bigger. That might be a factor in a car with a stock floorpan transmission tunnel. I have a 3rd gen F body and the drivers side is very tight to the bell.
the trans must come apart to install?
