Old 12-23-2019, 02:28 AM   #1
richie 2
Liked 205 Times in 93 Posts
Default th 350 ultra bell
r they worth the time & investment ? tks
richie 2 is online now   Reply With Quote
Old 12-23-2019, 11:49 AM   #2
jmcarter
jmcarter's Avatar
Liked 3,181 Times in 972 Posts
Default Re: th 350 ultra bell
With what combination? Makes a difference...
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-23-2019, 12:46 PM   #3
Jim Kaekel
Liked 534 Times in 110 Posts
If your car has a tendency to break bellhousings, yes. I would recommend taking the trans case to a competent machinist so it can be cut and the bell housing be registered so that it can be installed properly.
Jim Kaekel 3836 STK
Old 12-24-2019, 12:04 AM   #4
e vassar
Liked 271 Times in 107 Posts
I wouldn't pull my trans out just to put one on , but if it's already out,its a no brainer,,considering the cost.
Old 12-24-2019, 12:22 AM   #5
MR DERBY CITY
Liked 7,939 Times in 1,520 Posts
There is absolutely NO need to install a ultra bell on your tranny...UNLESS you are cracking the case. After you have cracked ONE case,...it’s a lifesaver....of course my ole buddy Captain Jack cracked 2 cases before he bought the bell.....
Old 12-24-2019, 01:14 AM   #6
richie 2
thankyou !!!
Old 12-24-2019, 10:37 AM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,934 Times in 581 Posts
Its the best way to go if you are in a class that requires a guard on the flywheel/ Bell housing. I have done several on Powerglides and they work real well.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 12-25-2019, 11:02 AM   #8
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
If you use a Bell that is easily removed and sent back for recert and a good quality Trans blanket, you'll save much $$ and frustration.....Worked for me!!
Dano is offline   Reply With Quote
Old 12-25-2019, 12:22 PM   #9
Eman
Liked 133 Times in 76 Posts
They are nice and strong but they are also thicker and bigger. That might be a factor in a car with a stock floorpan transmission tunnel. I have a 3rd gen F body and the drivers side is very tight to the bell.
Old 12-25-2019, 01:27 PM   #10
richie 2
the trans must come apart to install?
