#11 |
Liked 1,987 Times in 599 Posts
I have done several powerglides with out disassembly.
Mike Pearson 2485 SS |
#12 |
Liked 52 Times in 32 Posts
Unless the Bell is specific to a aftermarket Case, (Reid, etc.) they will bolt on with your existing pump bolts. The tricky part is the Sanitary cutting of your existing stock Bell
SC 707Y |
#13 |
Liked 205 Times in 93 Posts
so no trans shield required if ultra/bell used ?...didn't realize that...
#15 |
Liked 397 Times in 153 Posts
The ultrabell only replaces the flexplate shield, not the trans shield/blanket.
Phil Molski PMR Performance S/C 1623 |
#16 |
A good quality trans case blanket is less expensive than taking apart the trans, shipping, cert expense and shipping it back, putting back together, (if someone else needs to do this). Just saying...…...
SC 707Y |
#17 |
Liked 54 Times in 7 Posts
I have a TH350 Ultrabell on the shelf from an old combination. BOP ears have been cut off for firewall clearance so it only fits SBC now.
Kept cracking 350 cases in the bell housing until I went this route. $250 dragracer77@hotmail.com Chad |
#18 |
Liked 232 Times in 108 Posts
Thus, my request to allow removable tunnels in stock that was shot down. It's a shame they don't understand that people want to make a car safe but not such a P.I.T.A. to work. on.
#19 | |
Liked 320 Times in 102 Posts
and don't forget those dangerous glass windows because we would all be safer with Lexan.. Why don't we just leave Stock alone for a while rather than trying to " Fix it"
#20 |
You're probably right. Lexan would make it safer. I'll let you fight that battle. Just don't understand NHRA requires same safety equipment in a stocker VS Super Stocker but getting it to fit in a non-massaged tunnel is impossible on some cars. Not aware of Super Stockers running Lexan. ??
