#121 |
Liked 57 Times in 14 Posts
Welp, looks like 2020 will be the final year for us!
Mike Voth 5189 GTN - 5188 GTO Voth Racing |
#122 |
Liked 167 Times in 81 Posts
Correct me if I'm wrong but if you angle mill the head at an extreme angle thereby reducing the port volume and NHRA only measures the head port volume aren't these "spacers" allowing larger cylinder head port volumes? It's not really about adapting different intakes but using the "spacer" to raise cylinder head port volume as the head isn't measured with the spacer installed. I guess the port entry can be raised also. Seems like a reasonable rule change to me. Although I feel for those affected, anytime you push the rules you put yourself in a position to have the rules get tightened, not in you favor whether it's been accepted before or not.
#123 | |
The volumes are measured without the adapters. |
#124 |
Liked 5,125 Times in 1,953 Posts
Thanks , Joe
(123 posts later ;-) )
#125 |
Liked 124 Times in 39 Posts
I wonder if exhaust adaptors will be illegal too? I mean, the angle should be checked on the exhaust side, if the intake rule gets reinstated!
Sean Cour T6066 ladle |
#126 |
That's my point. If you mill the head at a severe angle won't the cc's of the cylinder head runner be reduced? You can then open the runner up in other areas to bring the head back spec. cc's. The whole point of doing it.
#127 |
Liked 101 Times in 52 Posts
That's what I thought. Besides a better intake you're gaining CC's to work with and possibly changing the entry angle somewhat.
#128 | |
Liked 689 Times in 198 Posts
From rule book SS heads - Must be correct casting number for year and horsepower claimed, per NHRA Technical Bulletins or NHRA-accepted. Cylinder-head casting must also be on NHRA runner volume list as published on NHRARacer.com. Porting, polishing, welding, epoxying, and acid-porting permitted. |
#129 | |
#130 | |
Sean Cour T6066 ladle Last edited by Sean Cour; 12-30-2019 at 11:46 PM. |
