Old 11-17-2020, 06:25 PM   #11
bykr
Liked 167 Times in 81 Posts
Default Re: Lug Nuts
I think most stud breakage is due to inadequate clamping force .ie lug torque.. Plenty of fast cars on 1/2" studs for years.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 11-17-2020, 06:36 PM   #12
Randy Wells
Liked 1,144 Times in 354 Posts
Well between Larry and my Brother Bob and the stories, looks like I will go with 5/8". Looks like plenty of meat on the wheel to drill out for Lug Nuts.,
Randy Wells is offline   Reply With Quote
Old 11-21-2020, 08:09 PM   #13
Capri
Liked 27 Times in 14 Posts
If you DO drill the wheels, wait til you get the studs. Now you are potentially looking at drilling and taping the axles,and front hubs also. On top of that, I am not aware of any sleeves made to go around the stud to sit between the wheel and stud. Just the larger nut and exterior washer. Most of the wheels I have had my hands on slip right over the "5/8" stud fairly tight tolerance. only had one a tad sloppy. Then just a half inch spacer and torque em at 85.
Capri is offline   Reply With Quote
Old 11-21-2020, 09:19 PM   #14
bykr
Originally Posted by Capri View Post
I\ Then just a half inch spacer and torque em at 85.
Strange lists 130lb. for torque. Even my 1/2" fronts go 90lbs.
Old 11-21-2020, 10:25 PM   #15
Run to Rund
Liked 54 Times in 27 Posts
I bent a set of 1/2" grade 8 on a mid to high 11 sec. car. I use steel wheels with aluminum drums (they might squirm more than steel or iron drums; don't know) and now run grade 8 bolts in 5/8". I don't torque over 120 ft lb with lubed threads; check what torque your wheels can stand.
Old 11-21-2020, 10:28 PM   #16
MR DERBY CITY
Liked 8,108 Times in 1,531 Posts
Good decision, REMEMBER, ....it’s cheaper to buy the BEST parts first.....
Old 11-22-2020, 01:36 PM   #17
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: Lug Nuts
If you run the 1/2 inch please note that you’ll need to bring extra studs (or be fortunate enough to be racing with Mike McMahon since he’s carrying extras even though he doesn’t use them anymore, ask me how I know). Matt Rover spotted my broken studs and that’s on a SS/MA car, turns out I was about to make a run with two broken studs, which of course would have been a very costly mistake.
I know how you know. Jim
