Old 03-30-2021, 12:11 AM   #1
Liked 5,134 Times in 1,958 Posts
Default Ford 302 Rocker Shims
Does anybody have a set that they could measure for me. I think they might work for my application, which looks similar.
Call or email me or just post the length , width and hole dia.
602-769-0346
myac455@gmail.com
Thanks
Old 03-30-2021, 08:21 AM   #2
pmrphil
Liked 348 Times in 152 Posts
Default Re: Ford 302 Rocker Shims
.540 X .865 and the hole is not round, it's .320 X .345
Phil
Phil Molski
PMR Performance
S/C 1623
Old 03-30-2021, 10:41 AM   #3
richie 2
Liked 205 Times in 93 Posts
crane cams i believe has them...
Old 03-30-2021, 11:38 AM   #4
SSDiv6
Mark,
What diameter and hole size do you need?
Prior to the rule change allowing aftermarket rocker arms, I used aircraft AN960 washers in Oldsmobile engine applications. They are available in 0.016, 0.032, 0.042 and 0.063 thickness. They are stronger than commercial washers and still low cost.
Old 03-30-2021, 11:57 AM   #5
Mark,
Yes, I've seen those for Oldes. These are rectangular, and I will check out the info above from Phil. Thanks
Old 03-30-2021, 12:26 PM   #6
SSDiv6
The aircraft AN960 washers are round and not rectangular. The engine did not know the difference.
Old 03-30-2021, 12:42 PM   #7
But it does.. Ford doesn't have any goofy bridges... The rectangle on the pedestal keeps the rocker on center ;-)
Old 03-30-2021, 12:48 PM   #8
I suppose you could use washers on a Ford but I'd prefer not to.
Old 03-30-2021, 01:31 PM   #9
rseibenick
Liked 20 Times in 7 Posts
Mark, Crane Cams Ford pedestal rocker shims 99170-1 Summit Racing. I use them on my Tempo pedestals.
rseibenick is offline   Reply With Quote
Old 03-30-2021, 04:16 PM   #10
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Ford Performance also has the pedestal shims ,part # M-6529-B302
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
