Old 04-22-2021, 11:25 AM   #1
garyc
Liked 51 Times in 30 Posts
Default fuel check
hi,
stock eliminator nhra still doing fuel check?? do i need a tap off fuel line next to carb? does someone sell a kit, i can most likely make one with brass fittings and petcock
Gary
garyc is offline   Reply With Quote
Old 04-22-2021, 12:37 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: fuel check
I bracket race but a lot of my competition is from NHRA legal S-SS cars. I have it after the regulator under the hood. I've seen it done on the cheep with hardware store fittings and $100 billet aluminum stuff that leaks. Long story short: if it's in the book, you need it. Checking it is up to the tech.
Dale Shearon
68 Mustang 6394
Old 04-22-2021, 01:13 PM   #3
SSDiv6
Liked 1,586 Times in 583 Posts
Originally Posted by garyc View Post
hi,
Gary
The problem with commercial fittings is that they may leak because the seal or "O" ring material may not survive when exposed to fuel and if you have an EFI system, they may not hold the higher fuel pressure.
If you have an EFI fuel system, that exceeds 60 PSI of fuel pressure, then you need the Aeromotive Sampling valve.
The Saf-Air fuel sampling valves are FAA approved and used in general aviation and affordable and even sold with a hose by RJ Race Cars. They have a brass and stainless steel version and have Viton seals.
https://www.aircraftspruce.com/catal...ircav110h4.php
https://www.mcfarlaneaviation.com/pr...roduct/110HSS/
https://quartermax.com/fuel-sample-valve/
https://www.appliedracing.com/an-fit...ple-valve.html
https://www.speedwaymotors.com/AFCO-...CABEgJOYvD_BwE
Old 04-22-2021, 02:20 PM   #4
garyc
thanks for the links
Old 04-22-2021, 07:33 PM   #5
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
Its really handy to have a way operate the fuel pump from the engine compartment, not required just handy. I use a momentary switch wired to the pump that I installed on the fender apron.
Kelly Lane
4991 STK
Kelly Lane Stk4991
Shadylane is offline   Reply With Quote
Old 04-22-2021, 09:40 PM   #6
SSDiv6
Kelly Lane
4991 STK
Is the switch wired directly to the pump, bypassing the ignition switch?
The rule book specifies that the fuel pump must shut off with car’s ignition switch.
Old 04-22-2021, 09:56 PM   #7
Shadylane
Shadylane's Avatar
It’s a dedicated switch that operates the pump independently of the ignition switch.
Kelly Lane Stk4991
Old 04-22-2021, 11:03 PM   #8
SSDiv6
Thumbs up Re: fuel check
Thank you for the clarification.
Old 04-26-2021, 09:04 PM   #9
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Kelly Lane
4991 STK
I have the same, very handy, make sure to use a momentary switch. I don;t have a return line on the pressure regulator, so I use that outlet and hooked up brass fittings and a brass shutoff used for an icemaker line.
Mike Moller
NHRA 203 Q-R-T/SA
Old 04-26-2021, 09:40 PM   #10
Gmirza
Liked 253 Times in 95 Posts
I use a fuel shut of for a Motorcycle. The type that screws into the bottom of the gas tank. It’s the same pipe thread as the outlet port of the regulator. Put a length of rubber hose on the barbed end.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
