Old 09-13-2021, 06:43 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Engine temperature
Converting to K/SA for F/PS noticed the new cam takes longer to warm up.
The Pure Stocker like to run better cooler.
Cooler the better.
Wanted to get feedback on ideal engine temperatures for LT1 engines.
Old 09-13-2021, 08:16 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Engine temperature
Are you running an electric water pump ? What did you do with the thermostat ?
Old 09-13-2021, 10:10 PM   #3
Dan Fahey
Dan Fahey's Avatar
No thermostat.
Stock Water pump with a auxiliary one installed to meet Pure Stock Rules.
Was not allowed to put a Meziere ..
Use the Stock fan to cool radiator.
Have no problem keeping it cool.
Asking if the engine like more heat because of the cam.
Old 09-14-2021, 01:19 AM   #4
GUMP
Liked 2,354 Times in 554 Posts
No.
GUMP is online now   Reply With Quote
Old 09-14-2021, 08:30 AM   #5
Ralph A Powell
Liked 225 Times in 136 Posts
Make a thin aluminum plate with a 5/8 hole between the intake and thermostat housing. It make take a 1/2 or 3/4 hole.
Ralph A Powell is online now   Reply With Quote
Old 09-14-2021, 10:34 AM   #6
ss3011
ss3011's Avatar
If you don't plug the hole below the thermostat then coolant will just circulate within the engine and wont go through the radiator . Like most small blocks , if you get the
engine cool ,below 140 F , on the starting line , it will make more power .
Old 09-16-2021, 08:11 AM   #7
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
Dan,
You are going from PS, to K/SA correct,? If so, just go to the electric water pump and you can then control the temp ny just leaving it off as you warm it up. I don’t know where those engine like to be heat wise but I would be surprised if the like to be over 140 at any time. Maybe someone will add that info.
When do you expect to be out?
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
